Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
OVEN WONT LITE. THE GLOW COUPLER GLOWS AND THE BROILER LITES
    President:
  • 1,891 Answers
Sounds like this is gas unit . if so replace the bake ( bottom ignitor ) as it is weak . and this should correct problem .. mm hope this helped ..
Posted on Jul 16, 2010
Gas burners on top of stove work but broiler & oven do not heat up.
Hello'
Does your model have an electronic ignition? If so open broiler drawer ,turn on oven and look for bright orange glow. May take a few seconds.If it glows but no or poor flame .replace oven igniter.If no glow at all , check for voltage at igniter when switched on to see if it may be oven thermostat . Get a tech to test if not sure.All easy to fix.
Hope this helps
Aug 16, 2011 | Ovens
Oven burner will not light, the ignitor glows though and the broiler does work
There are 2 seperate ignitors on stoves. One for the broiler and one for the oven. Ignitors can be bad even though they glow!
Jul 20, 2011 | Ovens
Oven won't ignite
most likely you have a bad ignitor.take out the racks and remove the floor,you'll see the ignitor,turn on the bake,the ignitor should glow and the flame should lite within 40 seconds,if it doesn't change out the ignitor,even if it glows that doesn't mean the ignitor is still good change it out.let me know what you find and next time send model number
Jun 20, 2010 | Kenmore 33169 Gas Single Oven
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Broiler light, oven wont
You are probably right though often the ignitor will glow, but just not hot enough for the valve to open. I would definitely try replacing the ignitor first, it is much cheaper than the gas valve and those valves rarely go bad. It is possible that the thermostat is not sending 120V to the valve, and thus the ignitor but less likely.
Jul 21, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Top coil
that is the normal way for the oven to work
Apr 13, 2008 | GE JKP15 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
91 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
