Question about Refrigerators
Hi. I have a Whirlpool conquest GS6SHAXKS01. The Icemaker seems to be harvesting ice correctly however, there is leaking, icicles, and a large block of ice behind the tray. I have read that it could be the icemaker itself or it could be the water inlet valve. How do I determine which one is the problem so I can buy the correct piece?
  • akozel Jul 16, 2010
    Thank you. I will be check this out.
  • 1,284 Answers
Hi, sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the useful life span of the valve and will also improve the ice quality.
Take care
Posted on Jul 15, 2010
  • akozel Jul 15, 2010
    Thanks for the feedback. Is there a way of testing the solenoid? I want to make sure that is it before I purchase the replacement.
  • Shehu Pro
    Shehu Pro Jul 15, 2010
    http://www.ehow.co.uk/how_5592107_test-v...
    Check it out here..
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
I have icicles all over my freezer. They started on the door under the ice maker. It is making ice but it won't come out because it the turning thing can't turn because there is solid ice in the bottom of...
Your icemaker is surely at fault. Shut the water off at the valve, turn off the icemaker, and defrost again. Does it happen again? If not, check your icemaker assembly for leaks or replace the water inlet valve if necessary. Good luck.
Apr 24, 2011 | Refrigerators
Icemaker not dumping ice, change bottom valve pump already, what else do I need to try,it already cost me 87.00, rerigerator not 2 years old yet. mod#ED5LVAXVBOO
ice maker has a heater on the bottom and when in harvest it warms the tray / so the ice will release . ck the heater . and thermo . .it also could be the motor that runs the unit . a easy way to ck it is use a jumper wire and jump T & H this will start the harvest , and if it will not dump replace the head . also freezer must be 15 deg or colder for icemker to work .. hope this helps mm
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ice maker ,no harvest?
Hi, The optics almost never go in those unit's, the problem is in the icemaker module itself. If you can jump it thru a fill and then no advancing thru to harvest afterward ( provided your freezer is below freezing ) it's the module. You can either replace just the head/module or the entire icemaker. For the difference of only about $50 I always replace the complete assembly. The most common one being about $150 complete, # 2198597 and this should be the one for your fridge since you mentioned the optic component's. Hope that help's. Thanks for choosing "fixya" for your fridge inquiry. Please take a moment and rate this solution if indeed it solves your problem. Thanks again and good luck. Macmarkus :)
Mar 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker leaking
what brand refrigerator?
Nov 27, 2007 | Refrigerators
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
