Question about Bryant 462AJC021BA Air Conditioner
The bearings in the fan motor (at top of outdoor unit) are worn
The bearings in the fan motor (at top of outdoor unit) of my Carrier
air conditioner model # 561cj024-C are worn and very loud. If I were to order the blade for the unit online, does the cost they indicate to purchase the "blade" include the motor that drives the blade as well? Parts pictures are generally not available and I cannot find a schematic for this model on line. Also, is online the best way to purchase the parts.
  • 57 Answers
Gotta say no to all of your questions.
The blade is a seperate part from the motor itself. If the blade is still good it can be put on the new motor. Best to use the same fan blade because they'll all pitched differently according to the amps it draws with the motor it's attached to. You could go to an HVAC supply house and get the exact replacement or W.W. Grainger is usually pretty good. If you don't have an outlet near you, they have an on line ordering site too.
p.s. be sure the motor is turning the correct direction.
Posted on Jul 16, 2010
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
Which capacittor to use with this unit? Carrier 38CKC036 Air Conditioner
depending on compressor it would be 40uf to 45uf 370v; 5uf/370 for the outdoor fan motor
Aug 01, 2011 | Carrier 38CKC036 Air Conditioner
E5 in control pane
E5 Outdoor activation of compressor over heatprotection or motor lock.
Due to condenser dust blocked,compressor get overheated-Clean condenser.
Motor lock- Due to bearing worn out- Replace bearing or motor.Thanks.
Jan 07, 2011 | Carrier 38CKC042 Air Conditioner
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
What is the part number for the outdoor fan motor?
as old as this unit is you probably cannot read the label on the motor it is either a 1/4 or 1/3 horse power 230 volt motor. a generic motor will work fine, use a 1/3 to be sure. also replace the capacitor so it matches the new motor. if you can read the label the part number is on it, should be an HK # with about 7 more digits
Aug 03, 2009 | Carrier Heating & Cooling
Outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Jul 22, 2009 | Carrier Heating & Cooling
Outdoor carrier cond. comes on but the indoor
Bearings in fan motro bad or bad capacitor. Depending on size of unit should be 5uf 370 capacitor. Replace cap. ans try to start unit.
Jun 10, 2009 | Heating & Cooling
Bryant 462AJC021BA Air Conditioner Logo
374 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
