Question about Acer AL1916W 19" LCD Monitor
How do I eliminate ripple effect on an acer AL1916W monitor
    Problem Solver:
  • 16 Answers
What is your refresh rate set to? At the desktop, with no windows open, right click the mouse and a dialog window will open. Click on properties, then the settings tab at the top, then another window will open. Click on monitor then at the bottom of the new window click on advanced. Check the refresh rate and change it to a lower rate and see what happens. You might even raise it. I hope this helps.
Posted on Jul 15, 2010
  • Jerry Perry
    Jerry Perry Jul 15, 2010
    Correction, when clicking on settings, then click on advanced at the bottom right, then monitor. The refresh rate is located there.
Acer AL1916W LCD monitor comes ON.. stays On for 2 to 3 sec and goes OFF
Same thing happens when attached to another PC?
There are more than one versions of this model as you can see here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Please read my guide first if you are going to DIY repair.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 19, 2011 | Acer AL1916W 19" LCD Monitor
My LCD ACER monitor AL1916w was not give actual resolution i.e. 1440x900. i am using window xp, Intel core 2 duo. Bhal
You can try installing the driver for the monitor,
http://support.acer-euro.com/drivers/downloads_gd.html
You alos need to verify that you have correct video card driver.
May 13, 2011 | Acer AL1916W 19" LCD Monitor
Acer al1916w a lcd monitor power up and shut down
It probably has porblem in the power supply/inverter board, you need to look for bad caps with domed tops, bad MOSFET in the inverter circuits, inverter transformer
See pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1916W/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 04, 2011 | Acer AL1916W 19" LCD Monitor
I got an Acer AL1916W 19" when I turn it on, It
Inspect the caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Dec 16, 2010 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
How long should my Acer AL1916W last, I bought it a little over a year ago and It's dead?
In my mind everything should last forever but cause most everything is manufactured overseas in bulk, there is bound to be problems cause of lack of quality checks and recalls.
In your case cause there is no power then its either going to be bad caps on the power board or a bad lcd that is shorting out the monitor.
Either way it would be more cost effective to buy a new monitor unless you have good soldering skills to where you can look for puffy caps and replace them with caps of the same value.
caps=capacitors
Jul 07, 2009 | Acer AL1916W 19" LCD Monitor
Grey Shadows for everythng on monitor
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Sep 02, 2008 | Acer AL1916W 19" LCD Monitor
Input Not Supported
You need to go into display settings, click advanced, and then click the monitor tab, and change the hertz setting to 60 HZ
Aug 07, 2008 | Acer AL1916W 19" LCD Monitor
Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Apr 03, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
299 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
