Question about Apple Mac/iMac&iPod Speakers-(Bondie-Blue) W/ Free CD/DVD Caddy-Limited Supply (p/n I-SPKR-BONDI) Computer Speakers
Mymacbook was having some problems so i ran vista on it and now it sais there is no internal audio speakers but it makes sound when it turns on how do i get the speakers to work again?
  • 206 Answers
Try re installing your audio drivers!! they will be in the cds which came with your macbook or will be in the drives try finding them and installing them it will solve your problem!1
rate and reply!
Posted on Jul 15, 2010
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Hi, I have a problem with my neo laptop. There is no sound from the internal speakers. I have uninstalled and reinstalled the audio driver and checked that it is up to date. There is only a brief muffled...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | NeoWave PC Audio Graphic Equalizer...
My Dell XPS M1330's internal speakers are not working, the audio utility claims that it is producing sound. I am running windows vista, and the sigma tel audio codec is my sound driver.
#1 Flash the BIOS to the most current version. #2 Run diagnostics from the F12 menu (Or Power plus FN key) see if the speakers work in the diagnostic. If they work in diags, there is no hardware issue, only a software issue. If you get no sound in diags, try a pair of headphones, if you still get no sound, then it is a hardware problem. If you only get sound in the headphones, then the microswitch that disables the speakers is stuck. #3 is sound works in diags then you have a problem with the audio driver or speaker configuration (Audio muted etc)
Jan 06, 2010 | Dell XPS M1330 Notebook
I have just installed speakers on my computer, but I can't get any sound.
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
Dec 09, 2009 | Dell Dimension 4600 PC Desktop
No sound coming out of my Mitsubishi Model CS-2013R (older model). Picture is still great. Just no sound all of a sudden. TV nor DVD player (running through it) project sound...
The older TV's have a switch in the back what if bumped will cut the speakers off. It is for internal/external speakers. Check the switch & make sure it is set for internal speakers. If that still does not solve it, go to your Menu screen advanced options and make sure the speakers are turned on. If it is and still not audio, then you may have a problem with the internal amp or the audio switcher. Note you will need the factory remote for the advanced options
Nov 08, 2009 | Televison & Video
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
I have a problem with my sound
have you installed the correct driver? , because Vista uses Realtek HD Audio and XP uses Standard Realtek Audio, also right click on the speaker icon>audio properties and make sure that speaker volume is set to the correct speakers and not headphones or somethong else
Aug 09, 2008 | Acer Aspire 5520-5908 Notebook
Help me
Same problem - Solved! Thanks Guys! I have Vista so the procedure was a little different. I went to Control Panel - Hardware and Sound - Manage audio devices. Once there I disabled the multimedia device and defaulted to the speakers which makes me fully operational again. Now I can crank Tequila! by the Champs.
Nov 09, 2007 | Audio Players & Recorders
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
