If your GPS is not finding any address, then the most likely cause is that the wrong country map is loaded or the map is corrupted as finding an address does not rely on getting any satellite signals (your GPS should at least show your home location or the last known position on the 'correct' map): I suggest that you look at your specific GPS user manual to find how to check that you have the correct map loaded: if it is the case, then find the instruction on how to 'reset' your GPS as its software may be corrupted.
Hope it helps.
CAR ALARM ISSUES
It
can be any of the car doors not got properly locked or the door is locked but
the switch is not sensing the door locked. Open and close each door again
properly.
Or
else its problem with any of switch wiring getting in contact
with alarm wiring causing it to happen.
And
last thing alarm connections need to be inspected. It's getting short somewhere
in between.
There
are few help links with solutions, to troubleshoot these types of problems.
I suggest going through these links.
Click
the link below: ------
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These
details will help.
Thanks.
