Question about Garmin nuvi 255W GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
  • Garmin Master
  • 3,289 Answers
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Posted on Jul 15, 2010
Garmin nuvi 1450 problems
You need to download a Garmin tool called "Garmin Express" to load the map software off the Garmin site.
May 19, 2017 | GPS
I have a garmin nuvi 265w and when i plug it itnton the cig cable in my taxi, it trys to load maps then goes off and on again. but keeps doing this without loading
You need to first check if the gps is charging, once you plug it in the cig cable, there ia a green light that shows it is charging, allow it to charge for some time before trying to use it. You need to take it out of the car first, then plug it into the main power socket to see if it will charge, if it does, then it means the charger and battery are working perfectly fine. Then you install it back in the car and try to turn it on, It should work now, but if it does not work, then you need to test the charging adapter and the battery separately on another garmin nuvi gps receiver. After testing you should be able to detect where the problem is from. Replace whichever is faulty and the gps should remain on and load maps. But if it does the same after checking, then it means all you have to do is to reset the gps.
Resetting the garmin nuvi gps receiver will do the job.
Hope this helped.
Dec 22, 2010 | GPS
I have a nuvi251 , it wont finish the map loading and stays with the green bar about 1 to2 mm from the end of the screen , wont go any further . Have turned on /off , removed and refitted memory card...
Welcome to Fixya
Sir/Madom,
Do Following
  • Check battery Charge
  • Try a hardware reset on the bottom of your unit[at bottom of Unit]
  • Update the preloaded maps on my Garmin device here
  • See this Video here [ instructions]
Also read Comments in this Page Here....
I hope you got an idea...Thanks for Contacting FixYa...
Jul 09, 2010 | Garmin GPS
When plugging into car outlet Garmin 200 goes into computer interface mode
You have to use a car charger with sufficient power capacity for your Nuvo 200.
I've used a mini USB car charger that came with my e-trex, but it works only some times when I do plug/unplugging during map loading (manipulating the computer mode setting). So, I bought a HTC mini USB care charger, and know the problem is solved. Another alternative is buy from Garmin Store, the type they recommend.
May 30, 2010 | Garmin nuvi 200 Car GPS Receiver
Garmin Nuvi 255w won't start up. tries loading maps and then goes in a continuous circle. acts if not charging. tried reseting and charging with wall charger and car charger
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
May 25, 2010 | Garmin nuvi 255W GPS Receiver
Garmin 1300 stuck on maps loading frozen I have a GARMIN nuvi 1300, running off a car cigarette lighter type charger, it was working fine for weeks, I got in the car, started it up and the nuvi is STUCK on...
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
Apr 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
When i plug in my garmin to my car charger, it will only show the screen of it being hooked up to a computer...i can no longer access maps when plugged in to charge
That could be because it is not the correct charger.It is going into interface mode.The small usb port is for downloading maps but I have seen some aftermarket charger that will charge through the usb port instead of the cradle bracket.Thanks
Dec 23, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
When I plug in the Garmin to charge it, the screen goes completely black and I get no directions. When I unplug it, the map returns with directions. Please help , Thank you James
If you are plugging it into your computer, or charging it through the USB port, the Garmin NUVI will go into "DATA MODE". You must use the car cradle to charge it and stay in navagation mode.
Mar 23, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
499 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
