Question about Stihl Chainsaw 42mm Piston Rings 025 O25 Chain Saw
Chainsaw seems to be burning the wood? - Stihl Chainsaw 42mm Piston Rings 025 O25 Chain Saw
    New Friend:
  • 7 Answers
Both of the above are right
Have a sharp chain and good quality lube. Even then hard dry wood will cause bar to get hot
The only way to stop this is to run more oil
Posted on Dec 12, 2014
    Problem Solver:
  • 5 Answers
Need more oil on bar
Posted on Sep 17, 2010
    President:
  • 2,220 Answers
If the chain is oriented as the lower portion of the photo it is dull.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
Chain sharpening is an art, if not correct it will not cut straight. I suggest you consider having it done professionally ($10± for 20" chain).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 15, 2010
Our Napoleon wood stove gets a gooey liquid that seems to come from nowhere and lays on top of the ashes. What would this be?
First what type of wood are you burning because some woods have less density than others . Then some woods holders moisture . Now this sounds like something called fat lighter this is a kind of sap which can ignite there for making it a breeze to start a fire . Some woods can be toxic so be carful . Pine is fast burning , where your oak and manzanita much slower burning. Stay Safe
Dec 11, 2017 | Home
Mt999 chainsaw. Brand new. Not cutting through wood although blade rotating. Just seems to be burning wood.
If it's all brand new, then sounds like you have the chain on backwards. The angled parts of the cutters should face forward while on the top of the bar.
Mar 16, 2014 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Won't start
In my dealings with electric chainsaws if you try to cut wood too big in diameter the electric motor burns out and you will net to replace the saw
Aug 23, 2013 | Homelite Consumer Products 9.0 Amp, 14 In....
Does uncovered firewood stored outside go bad?
Sounds like someone cut down some trees and stacked them in your yard. Most likely, it is good firewood. Actually, covered wood rots faster than air exposed wood because of lack of venting or direct exposure to the sun which dries up exposed wood. Covered wood stays wet longer which accelerates rotting. Thick round logs are hard to burn because they are not split. If you feel up to it, you can split them and burn them in your fireplace. Good healthy exercise!. If not, then Crags list would be my choice also.
Briketter
Dec 15, 2012 | Woodland International Chainsawbuddy...
Chain turns but comes loose and burns at wood. also get alot of smoke from chain area
Insufficent chain oil to the bar, check there is oil in the oil tank, remove the bar and clean out the delivery hole in the bar.
Jun 15, 2011 | Poulan 14" Chainsaw
I have a efco 165 chainsaw and for no reason i will be cutting good clean wood and it will just go dull. there's no cut marks inside like it hit metal. it has been doing it since it was new.
It seems like they supplied the machine with an inferior standard chain, replace the chain with a good brand and see if that solves the problem. (Chain saws are not too fond of cutting dry wood, they do far better in wet, green wood).
Apr 04, 2011 | Garden
My bosch ake 35s isn't cutting, what's wrong with it? chain turning as normal
Chain has dulled. Needs sharpening.
Hitting one little imbedded rock in the wood and the chain can be dulled to the point it only burns the wood.
Replace the chain or have it sharpened.
Apr 12, 2010 | Bosch Garden
Not cutting correctly - burning the branches
This is normally a sign of blunt chain, chain on the wrong way around or cutting wood that is too sappy or moist. Sorry if you are a regular/trained user and this seems patronising but it is the first things I would be checking if that was a fault on a cahinsaw in my workshop.
Feb 12, 2010 | Poulan Garden
My electric chain saw makita 5014 is not cutting seems to burn the wood. Can it need sharpening or a new chain. I am a mere woman and don't know too much.:o)
A dull chain can cause this so can installing it backwards. Find a local chainsaw seller/mechanic about 5 - 10$ to sharpen. Ask for their help to relinstall it. Stihl is the best dealer in my area.
fa94627.gif I have many chains when one dulls easy to swap in sharp one, no emergency to sharpen the dull one. HTH
Lou
Mere women are amongst the strongest things on the planet.
Oct 26, 2009 | Makita 5012B 12'' Electric Chain Saw
Was cutting wood when the chainsaw idled high then just stopped running
sounds like fuel mixture was wrong to lean not enough 2 stroke oil add u may have burned piston if wont start now
Jul 06, 2009 | Garden
Stihl Chainsaw 42mm Piston Rings 025 O25 Chain Saw Logo
1,247 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
ray gallant
Joseph Hoffmann
Are you a Stihl Garden Expert? Answer questions, earn points and help others
