Im getting C41 error on a toshiba e studio 207 how can this be fixed i tried resetting the machine what does this mean
  • yan dikshteyn Jul 19, 2010
    very accurate thank you
  • 532 Answers
The c41 error is an error in the fuser. if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.
You can use your manual to confirm the meaning of c41 before doing anything.
Good Luck.
Posted on Jul 15, 2010
How to remove c41 error toshiba estudio 225
C41Fuser theWhat does c41 mean C41 is fuser error...u can clear it using 08-400, reset any value to "0" ...If occur again, u need to check the fuser unit, especially themistor.
Jan 02, 2017 | Toshiba E-Studio 225 Multifunction Copier
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
How to reset Toshiba e studio 207 photo copier c46 error
e studio 207 model only have c41 to c45. there is no c46 error cord.
May 03, 2016 | Toshiba Office Equipment & Supplies
Toshiba e studio 225 c41 error comes
C41 is fuser error, enter 08-400 to clear the error, if still persist, check the fuser unit especially thermistor, heater lamp...
Jul 15, 2015 | Toshiba Office Equipment & Supplies
Test mode D comes up in toshiba e studio 207 by pressing 0 and 8 button during power on the machine a test mode D comes up so what I do ?
Practically you can exit by pressing 0&9 together and it will come to ready mode.You will see this kind of display only when you want to enter the service mode, now you will have to enter a value eg., if your machine gives error c44, then you can go to service mode and then enter 400 to reset the error.
Jan 20, 2015 | Toshiba e-Studio 207 Copier
How to fix error c41 toshiba e-sdtudio 18
I am unfamiliar with the e-studio 18 but on other Toshiba e-studio models C41 is a fuser (hot roller) error and it will clear itself when the problem is corrected, there is no reset procedure. I would go back and be sure that the replacement was done correctly.
May 17, 2014 | Toshiba Office Equipment & Supplies
C41 Error on Toshiba E-Studio 550
Get a decent piece of equipment. WHY would you throw money away on a bad copier?
Apr 15, 2014 | Toshiba E-studio 550 Copier - Fast,...
TOSHIBA E STUDIO 207 ERROR C 44
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0."
Jul 08, 2012 | Toshiba E Studio 207
I have a Toshiba studio 45 with error code c44, what can I do ?
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Oct 07, 2009 | Office Equipment & Supplies
Toshiba E Studio 35 error code C41
 C41 refers to Poor contact of the fuser drawer connector.
 Fix it!!!!
Apr 16, 2009 | Office Equipment & Supplies
76 people viewed this question
k24674
jasbo
jasbo
