Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Can not connect to router from laptop
My network was working fine. Now I can not connect from my laptop, or use my printer.
  • Checkmate123 May 14, 2008
    Can not connect to router from laptop was working fine before. Desk top works fine.
  • serra baby
    serra baby May 11, 2010
    -- do you have other wireless computer or device that is working on the network?
    -- what is the model number of the wireless adapter that you are using?
    -- have you check if the wireless settings on your router are still configured correctly?
  • 427 Answers
You need a wireless printer server to get your printer to work.
Posted on May 06, 2008
Cannon 560 printer is not connecting to the router.
It shows your router is not configured properly. Reset your router and reconfigure as per the instructions. Dont forget to name your network (ssid). After this ascan for the available network and then connect
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
Trying to share a HP Photosmart 7150 that is connected to an workstation with XP. The laptop has vista
If u have a router connect the printer to the router and it will be detected after installing the drivers on the sys.
If the printer is connected to the desktop pc than u need to share it with the laptop if the networking has been done or go aheaad and setup the network and than share the printer it would work fine
Feb 06, 2010 | HP PhotoSmart 7150 InkJet Printer
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are then set the network card to a high number say 100 then set the Subnet Mask IP address to
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
I am trying to connect my macbook pro 4.1 to a wireless printer. That printer works fine - when on wireless with my wifes windows machine and it works fine if i connect my mac to the printer- just not n a...
IN the case of the Mac what I have had to do in the past was shut down the other laptops and computers, delete the printer program from the Mac and start over. During the setup of the printer make sure nothing is connected to the printer. Only connect what you are instructed to at the appropriate time. It will eventually ask you how you are going to connect to the printer from that particular printer, answer ethernet cable and attach the ethernat cable to the printer from your router, make sure your laptop is connected to the router with an ethernet cable. Always set your computer up to the printer vis a hard line, then onve it is done you can swap over to a wireless setup. Once the setup is complete and a test print is accomplished bia ethernet cable, then disconnect the cable from the laptop to the router. Once you are connected to the network wirelessly, attempt another test page, you have already set the printer up at this point to be your default printing device so the laptop will find the printer on the network and initiate it. You may have to watch close for a pop up window asking to allow the connection or access to the program. Maybe think about dropping the firewall temporarily until the connection is secure.
Nov 29, 2009 | Computers & Internet
My reconnected printers cannot find my computer to connect through my Verizon FIOS router. The router works fine for my laptop. Printers worked fine a day ago, when they were routed through a second,...
If you are sure the network is working well (computers can see each other but your laptop doesn't see the printer). Got to network places/view workgroup computers. Double click on the computer directly connected to the printer. This will bring up all shared folders and the printer icon (if it is shared). Double click on the printer icon, and it will commence automatic installation on your laptop. Try this.
Sep 13, 2009 | HP LaserJet 1320n Printer
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Brother mfc 665cw connection error
I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
Mar 30, 2008 | Brother Multi-Function Center MFC-665CW...
Network router printing issue can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Printer networking
connect the printer to the router install the printer driver choose network printer it will then go off and find the printer and assign an IP address and make it availble for printing
Feb 18, 2008 | Computers & Internet
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
