Question about Hoshizaki Commercial Freezer KM-500MAH
3 beeps every 3 sec - Hoshizaki Commercial Freezer KM-500MAH
  • Hoshizaki Master
  • 1,238 Answers
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > 60 minutes.
Yellow LED marked 60 MIN energizes.
Check for F/S stuck closed (up), WV leaking by, HGV leaking by, TXV not feeding
properly, low charge, or inefficient compressor.
Posted on Jul 22, 2010
The KM-500MAE has 3 beeps in 3 seconds after 2 consecutive cycles. What should I check?
Hoshizaki has service info on line in pdf format on servicing and trubleshooting. The machine itself has info on what three beeps message is. Sorry, no pinpoint fix
Aug 25, 2015 | Freezers
Why wont my refrigerator run. Constantly beeps.
The beeping is typically a code. Is there an addition of a led flashing anywhere you can see?
Jun 15, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Freeze back up timer3beeps
signal means freeze cycle is longer than 60 minutes. Look for: stuck float, water valve leaking water into the sump, Hot Gas Valve leaking hot gas into the cold side of the refrigeration system. Start there.
Mar 06, 2014 | Hoshizaki Commercial Freezer KM-500MAH
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
3 beep code on hoshizaki km630mae
Freeze cycle too long. Usually about an hour. Many things can cause this. Look for water running even when machine is off. Stuck float switch causes this. may need a tech to check things out.
Feb 24, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My kenmore mod#2539183511 chest freezer comes on @30 sec goes off for @3-5 sec tries again.Need diag help or wiring diagram.
Sorry to read about your problem. you can have many different problems.
a wiring diagram will not help you in this case. all 3 items below at at the compressor.
odds are you will have to have the compressor replaced.
1. Failing compressor
2. Defective start cap
3. Defective overload protector
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Jan 02, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Compressor will come on for approx 3 sec and then go off with click and 8-10 sec. later try again
The start relay device on the compressor is faulty. replace this start device asap.
May 26, 2009 | Kenmore Freezers
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Frigidaire FRF170FF Freezer beeping
This is probably the defrost cycle. The beeps are the high temp alarm. It is probably overly sensitive.
Jul 04, 2008 | Freezers
Hoshizaki Commercial Freezer KM-500MAH Logo
185 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
