Question about LG 32LH30 32 in. LCD HDTV
LG LCD 32LH30 TV. Wireless USB Firmware?
I have an LG LCD 32LH30 TV. Are there any firmware updates that allows and enable LAN support with use of a USB wireless adapter off of the USB Service port ?
omaharox
  • 166 Answers
SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Posted on Jan 18, 2010
FixinFax
  • 3085 Answers
SOURCE: What brand USB Wireless Adaptor will work with my LG TV
Any brand of USB Wireless Adapter will work. Netgear, Linksys, etc
Posted on Apr 08, 2010
SOURCE: I have LG LF20 32
Even I am facing the same issue. Not able to enter into the service mode of 32LF20. Followed the steps from site http://www.answerspice.com/c134/425606/how-do-i-use-the-usb-on-my-lg-lf20-tv.
Posted on May 21, 2010
  • 8457 Answers
SOURCE: My LG LCD TV says that a wireless headset is
Tries unplug,replug tv it back an hour later,let the tv to reset itself back to factory setting.Should erase the strange command in the Tuner signal board.U should have audio now,after this resetting.
Posted on Oct 13, 2010
SOURCE: Hi! My Lg 32ld350 brick
LG-32LD350-CB.Change audio sistem DK,M,I for B/G.??
Posted on Mar 09, 2011
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
Problem downloading firmware
The firmware might be the latest available and no further updation found necessary.
Jul 14, 2012 | Samsung PN50C550 50 in. TV
Yesterday i have updated the firmware from v03.02.07 to v05.01.09 with the help of usb flash drive Now tv shows only LG logo and red light blinks Wont start TV only Shows logo please help me
I think, you have to downgrade the firmware:
get original firmware (I dont'now where) and
use RS232 cable to PC with nullmodem cable
In case "bricked TV" I solved this way it was 32LH3000
Oct 27, 2011 | LG 32 32LK450 32 in. LCD TV
LG 32LH40 Firmware Update. Has anybody found one? Or at least a way to update the codecs so that MKV files can be played via USB
At the following website there are lg tv firmware updates but the 32lh40 is not listed. Likely you will need to contact lg support. I was looking for one just for general maintenance on the same model.
http://us.lgservice.com/vchip_html/V-chip_upgrade_for_your_set.html
Dec 03, 2010 | LG 32LH40 31.5 in. LCD TV
My LG 32LH30 tv appears to be leeking fluid from the base
Only thing that have fluid is big capacitors on power supply board in LG 32LH30 tv, take off back cover and inspect power supply board to find out leaky capacitor that liquid is leaking from base.
There is nothing else in this lcd tv that can sent out any fluid.
Thanks.
Aug 26, 2010 | LG 32LH30 32 in. LCD HDTV
32LG3000 TV LCD - usb port ''service only''
Yes it's possible to use the USB port , you only have to change settings in TV setup to change it.
With software ver 3.15 it's very easy see link below how to change setup.
http://lgusb.wikispaces.com/#support
Feb 23, 2010 | Televison & Video
I have an 47LG LH30 LCD television, when watching shows that are broadcasted in HDTV, there is a delay between the sound and picture. How do I fix this problem?
You need to update to the latest firmware. This was an inherent problem in many LG LCD TVs released around the same time as yours but can be easily resolved by installing the latest firmware. You can call LG to have them send it to you on a USB flash drive or you can go to their website and download it along with the instructions. You will need a USB flash drive an plug it into your TV to intstall the firmware.
Nov 09, 2009 | LG 42LC2D 42 in. LCD HDTV
Centrios internet radio gives dhcp timeout
This is likely because out of the box, the firmware for this unit doesn't support WPA2 and even certain variants of WPA. I recommend: configure router for WEP or even open (i.e. unencrypted) connection, connect unit, go to setup/update firmware and let it update from network, power cycle, reconfigure your router for WPA or WPA2 security, attempt to reconnect unit to wifi. The updated firmware supports more formats and may allow your new router's config to work. You can also try doing the firmware update over the wired LAN port. Hope this helps.
Sep 27, 2008 | Computers & Internet
LG 32LH30 32 in. LCD HDTV Logo
896 people viewed this question
Computer Repairing
Computer Repairing
