Question about Maytag M7X05F2B Air Conditioner
Carpet wet under window air con.
Water drains inside instead of outside maytag#m7xo5f2a
  • Maytag Master
  • 3,289 Answers
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Posted on Jul 15, 2010
Why is the floor under koolking wet
If the drain is clogged or the ac is not slightly tilted towards the outside, the condensed water will leak inside instead of outside where it belongs.
Jul 17, 2014 | LG Heat cool Window Air Conditioner
My 2003 toyota camry on the driver side front floor matt, the carpet is wet. It is wet even though we have had no rain. and is hot.
Could be the A/C drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the cab. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, its been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the cab. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean.
Aug 03, 2011 | Toyota Camry Cars & Trucks
Where is the drain pipe on Suzuki air con
Hi are you sure its to do with your air con, normally when your carpet gets wet it means your heater matrix has burst, thats always been my experience. hope this helps thanks John.
Nov 24, 2009 | 2006 Suzuki Vitara
97 land cruiser wet carpet passenger side . have blown clear sun roof drain vents ..air con is dripping ok pipe outside floor pan ...no coolant usage ..no smell to wet carpet ... dried carpet drove last...
Does the car have climate control air/con?If so,air/con may still be coming on at different times.I would double check the air/con drip tray.Sometimes it has 2 pipes if the tray has split levels.One may still be blocked.(Does the car have a built in fridge?)Hope this may help
Sep 05, 2009 | 1996 Toyota Land Cruiser
During heavy rain water flows over my feet! Where does it come from??
most vehicle have a rubber drain plugs on driver and passenger side under the carpet. keep in mind you don't want to get lots of water under your seat because the computer mod sit right under the seat, if it gets wet it will cost you big buck to replace. good way to check it, next time when you get the next oil change or get the car up in the air, ask the mechanic to look at the rubber drain plugs at the bottom of your car and see if it still there and in good condition. pulling and lifting the carpet its not good idea and lots of work. If the the floor drain plugs looks good then check sunroof if you have one, check the seal around the roof making sure its has a good seal; it may not have a good drain. The last resort will be the fresh air duct from outside in front of the car next to front windshield, which is leaking through the unit. good way to also check the problems is take the vehicle to the car wash using high pressure water gun and spray in it fresh air duct for minute or two and see if its leaking through. hope that help some good luck
Jul 10, 2009 | 1997 Audi A8
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
96 chevy tahoe, passenger side and rear cargo carpet is wet
sounds like the air conditioning drain for condensation is plugged
Apr 24, 2009 | 1996 Chevrolet Tahoe
Interior Carpet Getting Wet
It sounds like a plugged drain line from the air conditioner. Most cars now run in the a/c mode whenever u turn on the climate control (even when heat is on). The passenger side front is where it would be wet, and the carpet and carpet pad act like a sponge and will soak up the water. Let me know how u make out.
Oct 25, 2008 | 2003 Honda Accord
Water under driver side floor
It may be due to the air conditioning hose being blocked. Therefore the water must be backing up into the vehicle, under the carpets and into the back seats instead of flowing out
Sep 29, 2008 | 1999 Lexus Gs 300
Maytag M7X05F2B Air Conditioner Logo
196 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
