Question about Canon ZR800 Mini DV Digital Camcorder
Playback problem hey everybody, i have a few thick grey bars running across the display screen when i playback video. the bars are NOT there when i shoot video, only on playback. a mystery! who can solve it? many thanks, happy earth day! hoag
  • 1 more comment
  • markwotton May 06, 2008
    I'm having the same problem. It worked fine for 4 months and now poof!
  • mikesmith101 May 18, 2008
    I am having the same problem as well - horizonal bars across the screen during playback that don't show up during recording. The bars go away after a minute or two.
  • cmknight1092 Jun 02, 2008
    I turned on my camera the other day to capture some footage I had shot with another camera and had a similar issue. For part of the time, though, the camera actually didn't even find a timecode on the tape. It was only after I fast-forwarded to about 10 mminutes in that it found the time code, but only with the grey bars. I tried a different tape and it had the bars, too. The good news is that these bars are not on the actual tape, because I have since played the same tapes back in other cameras and had no issue. I can't seem to figure out what it is, and I'm hoping it just needs a cleaning tape or something run through it. Has anyone tried this? It seems strange to me that so many people are popping up with this issue all at once. I'm had mine since January or February '07 when it first came out, and this is the first problem I've had with it.
I've encountered this exact problem a month ago, except cleaning the heads did not fix it. However, I was able to find an alternative solution...
After leaving my camera closed up in a drawer for a few weeks, I decided to take it out and leave it in the sun for 15 minutes, assuming that perhaps the gray bars were a result of moisture damage. The next day (Today, to be exact) I turned my camcorder on, and the gray bars have gone away from playback, as well as the reduced sound quallity it caused.
Posted on Jul 01, 2008
I looked up this problem on some other sites and they all suggested a dirty drum or dirty heads. I ran a cleaning tape (available at any Best Buy/Circuit City) through it and now every thing's working fine. Hopefully everyone who had a similar problem can solve it the same way.
Posted on Jun 03, 2008
How to elimate the circular moving dots during video playback?
That should just be a buffer. Give the video enough time to load from the source. Generally, there are two lines at the bottom on the playback bar, in the same space. Like, on YouTube for instance, there is the red line that shows how much you've watched, and a grey line that shows how much of the video is loaded. If not enough of the video has loaded, and the red bar catches up to the grey, it will buffer and show the circular moving dots.
Feb 04, 2013 | Computers & Internet
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Jul 20, 2009 | Canon ZR80 Mini DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon mv 830, grey horizontal lines across screen when replaying and a flashing red symdol which looks like a bowl with a slash across it and an arrow pointing down into it
Hi - I have just managed to fix this issue of grey stripes across my screen on playback on my canon mv800 by going into the audio format settings in the menu and changing the format from 12 bit to 16 bit - good luck everyone else! Sharon
Jun 12, 2009 | Canon MV800i Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
Playback/capture
Awesome. I might have to do that real soon myself.
Jul 02, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Grey Bars appear on video playback
The monitor you view while recording does not read from the tape where the problem is located, that's why you are not seeing them during recording.
Since they are not visible while recording, the video section is healthy, only the recording is faulty and it is unlikely you can do anything at home to correct it.
This may be a common problem and perhaps Canon is familiar with it.
I recommend you call their service line directly:
email: https://www.usa.canon.com/consumer/controller?act=SupportMailerAct&fcategoryid=227&modelid=12812
Phone: In the US: 1 (800) 828-4040
May 14, 2008 | Canon ZR700 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
898 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
