Question about Refrigerators
We have a 1996 mod.6162,ser.# 202380brbkb6, rv refridgerator
We have a 1996 mod.6162,ser.# 202380brbkb6, the lp sys would not start auto. but would if you manually lite it, now you can manually light it ,and a few seconds it will click off, also the electric part stopped one week end the next time out it worked , the next it did`nt, help, thanks Ron
  • 905 Answers
Hello Ron,
There might be a couple issues going on here.
First off, your flame sense is not working like it should. This is the electrode that partially sits in the burner flame. There is a wire that goes back to the ignitor module. Check it for continuity (electrode to connector), it should be near zero ohms. Also, check the screws on the burner housing assembly. These need to be tight and rust free because they secure the ground path for the ignitor. Make sure that your ground wires are clean and tight.
Given the history of the electric side, your power supply board may be on its way out as well. This can affect both modes (electric and gas, as well as 12volt cooling - but you are not equipped for that).
You can find a service manual at bryantrv.com. Look under the service manuals section, find the link for norcold 600
Posted on Jul 18, 2010
5 amp fuse keeps blowing on ac input into cir. brd. on norcold model 6162
shorted heater element unplug and see if it still does it if still shorted board
Jun 17, 2014 | Dometic RM2652 Refrigerator
Rv refridgerator works only on electric not gas
blow out LP line to ignitor if all other LP devices work if not LP issue
Jun 05, 2014 | Dometic Refrigerators
Norcold 6162
I'd be calling Norcold & asking if they are aware of this problem, the very least they can do is put you on to a reputable repair man to fix it.
Dec 01, 2013 | Refrigerators
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Mi carro de repente se memato y ya no quiso en cender al parecer era la bobina, pero el mecanico me dijo que siempre no, que probablemente puede ser un sensor del arbol de elebas...quisiera saber si...
mi carro plymount breezer mod.1996 motor 2.0 de cuatro cilindros de repente se paro y ya no quiso funcionar, no hay chispa hacia las bujias y la bomba de gasolina no funciona.segun me lo checaron y me comentaron que era la bobina y no fue despues que fue la computyadora pero ahorita ya estoy indeciso gracias
Apr 23, 2010 | 1996 Plymouth Breeze
Empire Mod#UH-1250-1FSP Ser # K49789WR Heater has been switched from LP gas to natural gas. I need proper orifice size to complete.
need to notify empire their specs for their natural gas should have the answer the kit or conversion unit should have had the part -it might not need to be changed--but if it does info needed is size of heater btu's size of line what kit/gas valve unit ur using
Jan 25, 2010 | Empire Heating & Cooling
Refrig in camper keeps freezing food even when on lowest temp
It's either the thermostat or the door seals leaking Since its freezing the refridgeration unit is fine
Oct 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
