Question about Compaq Computers & Internet
I have had two failed backup attempts and my d drive has only 19% free space. I have attempted a backup with disk should I purchase an external hard drive and if so how much memory should it have
  • 621 Answers
A hard drive needs at least 15% of free space at anytime to allow it to shuffle files around so this is really the only reason for your failed backup attempts. And yes an external USB hard drive is a great idea and seeming i can buy a 500G for $110 or a 1000G for $120 i know which one i'd be buying. Cheers from Scott and please dont forget to vote
Posted on Jul 16, 2010
WD MyPassPort 320 GB partially dead after an attempt to make it Win8 recovery drive.
Maybe you can try to format it to see if you can get the space back. But one thing important is that you may need to backup your files first. If not, you may lose them. Or you may try some file recovery tool after you format your drive. This may be help, I've try it, workable. http://www.uflysoft.com/data-recovery-mac/ Hope it can help and hope you can get back your 320G back.
Jul 16, 2013 | Western Digital Wd 320gb My Passport Elite...
When i switch on the computer it says that there is a hard disk problem found so you take back up of your files
Hi there, this means that your hard drive is going to fail. Take all of your important files and put them on a USB key or external device. A full backup is ideal if you have the space. You will then want to purchase a new hard drive and replace your old one before it fails and you lose all of your information. -Alex
Aug 15, 2011 | Computers & Internet
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
My 250g external appears to have corrupted data. windows says it fixed the errors but my last two attempts to back up my computer failed. How do I fix the external drive?
> fixed the errors
The disk-check utility does some "consistency" checks:
* every file listed in the the Table-Of-Contents actually exists on the disk-drive, with no exceptions,
* every file on the disk-drive is listed in the Table-Of-Contents, with no exceptions,
* every "block" of data on the disk is either "free", or used exactly _once_ by a specific file,
i.e., no block on the disk is unaccounted-for, and no block on the disk is "owned" by _more_ than one file.
The disk-check utility does _NOT_ read each "block" of data on the disk, to confirm that each block is "readable". Only when the file-backup attempts to read a file, does the inability to read that block get exposed.
Similarly, it's only when the file-backup utility is trying to write to one of the "free" blocks,
that the inability to write to that block get exposed.
So, what you need to do is to run the 'FORMAT' utility on the external disk-drive,
and to choose the "full" option, not the "quick-format" option.
The utility will try to write to each block on the disk.
When the utility detects a "bad" block, the utility will either flag that block as "never-to-be-used",
or the disk-drive itself will designate one of the "spare" blocks on the disk
as the permanent substitute for the "bad" block.
When the utility completes, it will either report the number of "bad" blocks,
or it will report ZERO "bad" blocks (because the drive's own electronic circuits
will have done that "substitution" in a "transparent" manner).
After the FORMAT completes, try your backup again. It should work.
Nov 03, 2010 | Toshiba Computers & Internet
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
Oct 30, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Clarification re WD My Book storage space issue
this happen to a cousins laptop the only way to get it to sort out was to format the drive.it sounds harsh but it was the only way.
Dec 06, 2009 | Western Digital WDH1Q5000N 500GB MyBook...
The little Maxtor icon is red; what does this mean and how do I fix it? Thanks. scbriel@comcast.net
That means that your last backup has failed. This could be caused by a number of issues and you should double click on the icon to open the program and check the log. Normally when you are attempting to backup a file that is locked by the OS such as a system file it will fail to copy. This could also happen if a file was moved or removed that was flagged to be backed up while the backup process was running or if you ran out of free space. Honestly, your software's error log will be the best thing to check for a solution.
Jul 28, 2009 | Seagate 750GB One Touch 4 Lite-maxtor USB...
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
May 17, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Computers & Internet Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
