Question about Haier Preference Plus HWR06XCA Air Conditioner
Won't run, getting an E1 error in display screen
    Genius:
  • 1,417 Answers
what this E1 mean is an error sign that indicate that there is a loose of wire from the connection
what you will have to do to fix up this problem from here is to unscrew (open)the system with stroll driver on the stroll then trace the wire from the power supply down to the sensor that is the control unit fix up the wire will be either in red or blue color that supply power to the control unit please while doing this you will have to be very careful with other wires connection in other to avoid more damage on the unit then clean up the panel of the control unit after you have unscrew the system
thank you and thanks for using fixya.
Posted on Jul 15, 2010
  • beansshu Jul 15, 2010
    What is a stroll driver and stroll?
  • Oloyede Monsuru Jul 15, 2010
    hello,
    stroll driver is a technical tools that is use for unscrewing luck stroll
    while stroll are lucking mechanism use in coupling up electronic
    at all lock joint.
    thank you
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Error e1 during running
    try google with model# and the error code
    Jul 21, 2015 | Whirlpool Washing Machines
    Fault code F1:E2 what is this fault
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks
    Oct 10, 2011 | KitchenAid KGST307 Gas Kitchen Range
    My whirlpool oven locke with F5 E1 what to do
    Thanks
    Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
    The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
    You should disconnect power for 15 seconds and reconnect and see if that helps.
    If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
    Thank You and please rate my answer if it was helpful..
    Jun 19, 2011 | Kenmore Ovens
    The range displays f5 e1 when i try to run cleaning cycle
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&*(
    May 12, 2010 | Whirlpool GS460 Gas Kitchen Range
    I have laars heater model ht 330. there is no hot water and the heater displays error code E1
    E1 is only the first part of the error code. There should be one or 2 more digits being displayed, alternating with the "E1" display. Unless you provide the other 2 digits of the error code, I can't help you.
    You can get the user manual for your boiler/water heater with the error codes from here:
    http://www.blueridgecompany.com/documents/LaarsHT330.pdf
    Please, get back to me if you need any more help
    Alex
    Mar 21, 2010 | Heating & Cooling
    Display screen reads E1 F5.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^
    Feb 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Error code
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
    Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Kemore he3 dryer error code E1
    Hey fookie you need a thermistor for that dryer. It runs with no heat ?..Let me get a pic for you it is about 25 bucks oh and is part 42 on the pic below
    Oct 23, 2008 | Dryers
    Haier Preference Plus HWR06XCA Air Conditioner Logo
    53 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Bonded Repair
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
