Question about Toro Lawn Mower With Toro Power Tools
I hit a metal pipe while cutting grass. Lawnmower immediately died. I restarted it and it began to clunk and shoot out white smoke. I tried to cut some more grass but it died under load. Lawnmower is no more than a year and a half old. It's a Toro selfpropel
    President:
  • Toro Master
  • 1,545 Answers
If you are lucky, you have only sheared the flywheel key and messed up the blade. The flywheel key is under the top cover and under the flywheel along an indent in the side of the crankshaft. Those parts would have to be removed to check it....most likely it's sheared (broken) which is what it is supposed to do (most are made of aluminum) when the blade hits an immovable object. It CAN be fixed and there are videos and forum HOW TO's on this subject. A new key is very inexpensive and replacing one is a good learning experience.
Posted on Jul 15, 2010
Testimonial: "rycgl, I thank you for giving me very accurate advice. I took the flywheel off and sure enough the flywheel key had been sheared off. "
  • 3 Answers
The is a key on the crankshaft that's broken. You have to pull off the flywheel and replace it. It's made to break like that so there is no more damage than the inexpensive woodruff key.
Posted on Aug 29, 2010
Turns over then cuts off
Clunking noise sounds like a piston to crankshaft problem. You can do a compression test to determine the bad cylinder.
Jan 23, 2014 | Ford Expedition Cars & Trucks
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Mower is not shooting the grass out when using the mulcher. I have to clean the grass out when cutting the grass.
Maybe the grass you are trying to MUCLH is a little too high. Mulching doesn;t really cause the machine to "shoot" out the grass the way conventional cutting with a conventional blade does....it is the type of blade that when spinning, creates air pockets under the deck that allow the blades to keep cutting the grass over and over. Switch to a different blade to get it to shoot out.
Aug 13, 2010 | Black & Decker Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Lawn mower keeps cutting off
from the sound of what you are describing the piston/rings/cylinder are damaged in some way shape or form this causes compression loss in the engine, and allows oil to enter the combustion chamber, in this case a new lawnmower would be in the near future
Aug 11, 2009 | Garden
Very little grass is shooting into the bag to fill it
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
747 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
