Question about On-Guard Alarm with Wireless Siren, Remote Keyless Entry, and
Battery died and I am having trouble getting my car to work afterwards
  • 387 Answers
If the remote keyless entry remote battery is totally lowbatt. open the remote and remove the battery, for emergency option, manually recharge it by contacting + and - terminal to charger or any source of dc voltage that compatible to your alarm battery, then assemble it again and try to operated on your lock unlock system
Posted on Jul 15, 2010
Car wont start no sound starts with a jump but dies shortly afterwards
Check connections to alternator; if everything is tightly connected then have it tested. You should also have battery tested as the car may have been running directly off it.
Mar 17, 2017 | Cars & Trucks
New starter wont start just click
change battery cables. get rid of those small gauge wires and put wire in that will draw amps. I had one car that would kill battery every year and found out the cables were to light to keep it working properly.. both the positive to the starter and the ground cable are way to small for the car. clicking means it isn't getting enough power to the starter to spin the motor !
Sep 17, 2013 | Dodge Neon Cars & Trucks
2005 Chevy Aveo, clicks but start won't catch and when jumped it doesn't charge what could it be??
Your alternator is not charging the Battery, I would replace the battery with a new gel battery and have the alternator checked, bets on your battery just died.
Apr 14, 2017 | 2005 Chevrolet Aveo Sedan
Buick security light flashing? How to reset security?
If you have a remote key fob for your locks etc it very much sounds like the battery is dead which will cause the car to"lockdown" so-replace battery. Good luck!
Jul 11, 2012 | 1996 Buick LeSabre
I have a 1990 Volvo 240 recently the car started to die at random times while driving. When it dies all the dash lights come on can't start it for a bit afterwards. I replaced the battery and it seemed...
  • This is classic of your alternator going bad. Sometimes, when it first begins to go bad it will function on and off. Soon it just stops charging the battery all together. The battery has one function and that is to start the car. Then the alternator is ran by the belt and charges the battery and in effect runs the car. The reason for the lights coming on is the power fail in the car.
  • Buying a new battery worked for a short time because the fresh battery ran the car but with no alternator to charge the battery the car soon died again.
  • The fix is to replace the alternator. Do it soon or even that new battery will go bad from being drained so much.
regards, Tony
May 18, 2011 | Volvo 240 Cars & Trucks
My 97 lincoln town car won't start. it's cold out. would taking the battery inside be a good idea to warm it up?
Your battery is usually challenged in cold weather, you are right...to much trouble to remove to take in to warm up...Do you have a battery charger? My suggestion would be to jump start your Lincoln with another car battery...this will assure that your battery is not further damaged by being under charged in cold weather...drive to assure charging system ie alternator is working...taking the battery inside to warm will help to save your battery if it is just low on charge...taking inside will not ncecessarily re-charge your battery...in the summer, sometimes leaving hood up with sun on battery will slightly re-charge a low battery...:)
Dec 13, 2010 | 1997 Lincoln Town Car
1994 Grand Cherokee, 5.2 V8 shuts off when hot. Cool for an hour or 2, starts up ok for a half hour or so, then dies again. No trouble codes except 12 and 55; I pulled fuses to check them, hence the code...
Your engine computer is bad. It's a good thing that you mentioned about the check engine light dying also, as this is a classic sign of a bad ecm. I have repaired more than one of these Jeep computers, replacing the three power capacitors located inside the computer, and they have worked for years afterwards. If you don't have the skills or knowledge to repair the ecm, get yourself a rebuilt ecm unit and swap it out.
Sep 28, 2010 | 1994 Jeep Grand Cherokee
Toshiba Satellite L305D laptop just died, and now won't power up?
Try remove the battery then power up, there may be a problem with the battery. When you put it back in afterwards it will work
Feb 13, 2010 | Toshiba Satellite L305D-S5914 Notebook
Battery and alternator are good but still dies
who ever tested your alternator was wrong replace the alternator
Mar 18, 2009 | 2001 Pontiac Grand Am SE
On-Guard Alarm with Wireless Siren, Remote Keyless Entry, and Logo
384 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
