Question about Hayward SAND FILTER, PRO SERIES
How use the filter
How to use the filter hayward model s244t
  • 760 Answers
Go to : http://www.haywardnet.com/inground/products/manuals.cfm
you can download a manual for your filter. You didn't indicate what type of problem you're having
Posted on Aug 07, 2010
Hayward pro series s244 im getting large amounts of sand in pool and the system is drawing lots of air what could be wrong
Either broken lateral drain assembly or the manifold.
If fairly new filter, it could be that you have overfilled the amount of sand, as it is too close to the bottom of the variable position Multiport filter valve.
Hayward SX244DA Lateral Assembly With Pipe
May 24, 2015 | Hayward Industrial Products Hayward Pro...
How do I make sure I reassemble my Hayward sp0714t
Hi This is John the Hayward tech. I have attached a link to the manual for the 2244T. Not sure if you took the valve apart or have taken the valve off the filter and just need to put it back on. Let me know if the manual helps http://www.hayward-pool.com/pdf/manuals/ProSeries-S180T-S210T-S220T-S244T.pdf
Sep 01, 2014 | Pool & Spa
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
Jan 06, 2014 | Hayward SAND FILTER, PRO SERIES
I have a seam crack in s244t hayward pro series sand filtration series near the top on the tank and it is making a load noise. It's only a year old cannot get a hold of ANYONE at hayward, do we need a...
If the tank is cracked, you most certainly need to replace the whole thing. This should be covered under warranty and the local Hayward Warranty pool guy should be able to take care of this for you. Call one of the pool supply stores in your area and they should be able to direct you to the local warranty person.
Sep 04, 2011 | Hayward SAND FILTER, PRO SERIES
I have a brand new S244T sand filter. During backwash cycle large amount of water discharges out of the waste line. Filter doesnt appear to be backwashing normally. Hayward is sending a replacement head. I...
When backwashing with this valve, it is supposed to come out the waste line. Also when in "rinse" and "waste" it will also come out the waste line. It is acting just how it is supposed to act.
May 26, 2011 | Hayward Pool & Spa
I have an Hayward Pro Series S244T filter and I have had problems with sand blowing back into pool - the filter is only 2 years old
When sand returns to the pool, there is a hole in either the media or the sieve that is supposed to keep the sand in the filter.
All of the sand must come out of the filter, the sieve at the bottom (outlet of the filter) must be removed and any broken segments must be replaced.
The sand is then returned.
Gary
Apr 27, 2011 | Hayward SAND FILTER, PRO SERIES
We have a Hayward Pro Series sand filter S244T. It was installed 3 years ago. There is no indication of flow through the glass bulb on the back of the valve when the valve is in normal operating...
The sightglass is designed for backwash only, it allows you to see the degree of clarity in the effluent water. There should not be flow through the sightglass when the filter is in normal operation. Sometimes the pump will be alot louder when you backwash because there is alot less back pressure and it sometimes causes pump cavitation. The pump should quiet down when in normal filter mode. If not, there may be problems with the bearings and/or cavitation.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
I have a hayward S244T sand filter and the lettering on top of the handle is gone and I don't know anything but filter and backwash I would like to know if it has a recirculte position and where it is on...
Thank you for posting your question here on Fixya.com.
The 'manual' for their multiport valves, found here, shows the layout of your settings.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 30, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward S244T filter spraying water at top
Just an o-ring and the 2-piece clamp that compresses the two pieces together.
Jul 28, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
96 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
