Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can you help me find the fuel filter on my Husqvarna 137 chain saw? TIA...
    President:
  • 2,220 Answers
A liknk to an IPL (Husqvarna 2004 137/137e) follows; may not be your saw:
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401903.pdf
Page 4 item 29 is an illustration.
Insert a blunted, hooked piece of wire through the fuel filler hole and gently pull the hose out. The filter should be on the free end of the hose.
All Husqvarna IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 15, 2010
Testimonial: "Just what I needed, and quick, too, thanks a million!"
  • dontbother10
    dontbother10 Jul 15, 2010
    You are more than welcome Bill. Thank You for the rating and kind words.
    Lou
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
Fuel mixture for a Husqyarna E-series 137, mod/137802010
The mixture should be 50-1 with Husqvarna rwo stroke oil, it is recommended that you use a mixture of 25-1 with other brands of two stroke oil, this is because they do not know the quaility of other brands, always try to find genuine Husqvarna oil.
Aug 27, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The chain brake on my little 137 husqvarna saw is broken. The metal strip is snapped . Do I need to buy a complete new brake assembly or can I get only the metal strip and fit it into the perfectly good...
You ask a 2 part question, I start with brake band repair/replacement.
A link to a 2004 Husqvarna 137/137E IPL (exploded parts list) follows (may not be your saw):
See the Chain Brake illustration, item 13 for the band. Item 14 (see Bailey's description. Your local Husky dealer will save shipping fees and is likely about the same price.) is a complete clutch cover $22
Sep 13, 2010 | Husqvarna Garden
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Aug 25, 2010 | Husqvarna Chain Saw 20" Bar
How do you start a husqvarna 137 e series chain saw
Hello Sally;
A link to an OM for a Husqvarna 2005 137 (no e listed, the procedure is the same) can be found here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_O0501001.pdf
The start procedure begins on page 9.
The part that says once it attempts to start open the choke is often overlooked and they flood.
This is the only 137 listed, normally there are many to choose from. If you need additional help Husqvarna can be contacted here:
Lou
Aug 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to assemble the chain brake on a Husqvarna 137 chainsaw
A link to a Husqvarna "IPL, 137/ 137 e, (revised 2008-04) 2006-12, Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601906.pdf
Page 1 displays the chain brake in good detail. The hand guard must be rotated aft to latch the brake band in the expanded position or it will not be possible to reinstall the cover. It requires a fair amount of force to latch and a vise (use wooden blocks on cover flats to protect the finish) or a large C-clamp to a work surface will probably be required.
HusqvarnaUSA.com (if the above is not your saw, IPL displays parts)
06 1500198
Lou
May 06, 2010 | Husqvarna Garden
Husqvarna 137 Chain won't stop when idleing. I turned the T screw down just enough to keep it running chain keeps on going. Could it be the clutch?
your carburator is gummed up. Get some carb. cleaner additive for your fuel, run a couple of tanks of treated fuel through the saw and it will be ok.
Feb 01, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Tell me how to chage my fuel filter on 350. It does not want to start, feel like it not get fuel
Hi there
The fuel filter on the chain saws are inside the fuel tank . The filter is connected on the fuel line that runs from the tank to the carburator .
Hope this help
Aug 31, 2009 | Husqvarna Chain Saw 20" Bar
137 stalls
Sounds like an air leak somewhere. Or possible a clogged fuel filter.
Mar 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
516 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
