On a tochiba e studio 270 how do i get into service mode and reset the needs maintenance error and how do i get PM life counters on each unit for thids machine
    President:
  • 567 Answers
Hi thanks for asking please click the link and choose the manual for you model and follow the steps http://www.copiers.toshiba.com/usa/support/training/index.html
Posted on Jul 15, 2010
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
How can I remove code m2 in Minolta 215 coppier
Hi fatma, this is most likely a maintenance counter error. You need to reset the maintenance counter. Do so by pressing: Select [Service Mode] [CLEAR DATA] [PM COUNTER]
This should enable the printer to start working again.
Hope this helps!
Oct 28, 2014 | Office Equipment & Supplies
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
You can use the Toshiba e-studio 160/200 service manual for this machine,
Enter 08 Service mode and:
check these addresses
340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
250 is 33,000 copies. If set to 0:Nothing displays.
673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
SRU: Service Replaceable Unit.
CRU: Customer Replaceable Unit.
Good Luck
Jun 27, 2011 | Office Equipment & Supplies
The error indicator is staying lit constantly on Toshiba e-studio
The drum counter reaches 25000 copies , it's time to change the drum and reset counter .
Enter the reset mode by pressing : # - * - c - * .
then press : 20 - start -01- start - CA - CA .
Hope this will help .
Feb 28, 2010 | Toshiba e-Studio162D Copier
I have a wrench code on my EStudio28 & machine went down-for days it has said periodic maintenance, can this be reset
Periodic Maintenance will appear if the PM counter setting is reach.
Normally, it wouldn't affect your machine, just that the message will shown at panel.
U can enter setting mode 08-252 to, set "0" to clear the counter, or 08-251, set "0" to disable the PM counter.
If your machine having problem, totally cannot run, u can enter 08-253 to display the last 8 error codes.
Mar 11, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba studio 35
switch off...hold down 0 + 8 keys,
switch on holding keys for 5-10 secs then let go.
service mode...
punch in 251 then print key should show pm set figure,punch in say / add 20,000 on to figure then press set in the display.
switch off then on should have cancelled prevent maintenance.
Jul 16, 2008 | Office Equipment & Supplies
Cannot get the machine out of PM Maintenance mode
to reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
Jul 10, 2008 | Toshiba e-Studio 350 Copier
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Nov 16, 2007 | Toshiba e-Studio 350 Copier
101 people viewed this question
jasbo
jasbo
