Question about Ungo K20 Remote Keyless Entry with GDI & Multiple Vehicle Operation
Can the Ungo K20 be used in a vintage car to engage 40lb. actuators to open the doors? No other functions of the remote are needed.
  • dillarddon Jul 16, 2010
    I wired the red wire to constant hot +, the black to gruond -, the black/blue to the left door actuator, and the blue to the right door actuator.
    The remote key fob device sends a signal to the receiver but the receiver does not send output to the blue or black/blue wires.
    Do other wires have to be hooked up for the receiver to function properly?
    Guru:
  • 528 Answers
Hi. Yes it is possible to use Ungo to your vintage car. I have provided you alink for the manual and instructions for your Ungo K20. Please click here.
Posted on Jul 16, 2010
    I already have the manuals but they do not clearly coer how to wire the system to perform only one task.
    Sergeant:
    Champion:
  • 230 Answers
If the only purpose would be for the actuators to open the doors I believe that won't be a problem at all, since the built of these vintage cars might be a little different and other features of the the remote might not function.. =)
Posted on Jul 15, 2010
  • dillarddon Jul 15, 2010
The drivers side door lock will not actuate with the remote or the interior switch. The key will open and close the door. All other door locks function properly with remote and interior switch.
Suspect a defective door lock motor/actuator inside the door. The door will have to come apart to test for proper ground and power supply to determine if motor/actuator is bad.
Jul 12, 2015 | 2011 Ford Focus
Honda CRV-EX 2003: remote not working. Battery OK. Hear attempt to open or close but door buttons wont operate. Hellllp!!
If you have replaced the batteries in you remote(s), and you can hear the locks attempting to work, your door lock actuator(s) maybe faulty. The actuators are not expensive, but the labor to have them installed can be.
Dec 15, 2014 | Honda Cars & Trucks
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Honda odyssey door lock driver side
Pop off the door panels & remove the plastic film. There's a white plastic actuator attached to the lock. You can test for voltage from the connector, but unlikely that's the problem. My symptom was the actuator was moving but not actually locking. It turned out mine was loose and I fixed mine by just reattaching the actuator. There's several screws holding it in there and mine came loose. Use lock-tite because it came loose a second time. If the motor isn't functioning then if you disassemble the actuator you might be able to search on EBay for a motor - the rear tailgate uses a Mabuchi. Otherwise you will need to replace the actuator. The rear one is about $80 online.
Mar 18, 2013 | 1999 Honda Odyssey
2006 Ford Fusion right rear door will not lock with remote
Sounds like the electric actuator is not connected inside the door.
Aug 20, 2012 | 2006 Ford Fusion
Automatic Doors won't function-How do I fix or what could be the problem
The door doesn't open with the remote or the in-car switch? I'd check the fuse, then check for power to the door actuator when the button is pressed. If there is power at the door actuator then I'd suspect a bad actuator motor. If there isn't power, please post back and I'll put my thinking cap on.
Dec 25, 2011 | 2002 Chrysler Town & Country
Drivers door will not unlock with the remote drivers door will not lock via internal button drivers door does not lock once car above 10 mph all other locking/unlocking functions ok recently had...
That sounds more like the lock actuator inside the door is bad since it does not function in any mode.You can call a dealer to ask about the possibility of a remote reset.Is this a Mini Cooper?It is listed under mini but I would think they would use the full name.If the remote can't be done and you want to self-repair,just comment to this post and I will get an auto link and I will try to describe how to get inside your door.Good luck! Greg
Aug 28, 2010 | Mini Cooper S Cars & Trucks
I have an ungo remote start/alarm. This AM the car would not start and the alarm went haywire- kept going off, took control of the car, A/C going on and off, etc. Had to disconnect the battery to get it to...
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
Jul 30, 2010 | Ungo SR6000 2 Way Security with Remote...
Automatic side door will no longer open with remote or console button in car. Also, both side door's locks will not pop up using all of our 3 remotes (1 door is automatic, 1 is manual). Lastly, the back...
Did these doors quit at the same time or over a period. It seems that the actuators for the locks have gone bad. With the mentioned doors, that's a lot weight for the actuators to unlock and pop open. With the remotes and console not working , that's more reason to think the actuators are the problem.
May 02, 2010 | 2002 Chrysler Town & Country
05 Honda accord remote not working doorlocks
Your door actuators are out and will need to be replaced. This is a common problem . My 03 has this issue too. Actuators are about $70 each. I would recommend finding a good stereo shop to install them instead of the dealer since stereo shops deal with removal of door panels and actuator installs day in and out.
Oct 04, 2009 | 2005 Honda Accord
Ungo K20 Remote Keyless Entry with GDI & Multiple Vehicle Operation Logo
75 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
