Question about Lexmark X654de MFP All-In-One Laser Printer
How to clean a X654de LexMark Printer cartridge to get more copies out of it?
  • 206 Answers
1.Take out the ink cartridges
2. get a soft cloth or papertowel
3. you are going to need a bit of isopropyl alcohol
4. take a tiny bit of rubbing alcohol and dab the place where the ink comes out with it lightley
5.Be very carefull! leave it out to dry for at least fifteen minutes
6. then put the ink cartidge back in to your component
7. make sure that the cartridge is in place and pushed in the right way so that it can be used properly
THIS MAY BE A BIT MESSY SO I WILL ADVISE YOU TO WHERE GLOVES!!!
HOPE THIS HELPS!
Posted on Jul 15, 2010
  • data66 Mar 30, 2012
    I believe this is a laser printer , it doesn't have liquid ink in it. Your solution does not apply.
Lvps cooling fan failure on lexmark x654
LVPS cooling fan is obstructed or has failed.
1. Check for cooling fan obstructions.
2. Check the connections on the main cooling fan.
3. Replace the print cartridge cooling fan.
Nov 12, 2012 | Lexmark "x654de multifunction monochrome...
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
When I print I am only getting various wide lines and no words or content. What is wrong with my printer
Do you get the same result when making a copy using the Copy button on your printer? You can try to clean the cartridge nozzles. Refer to this article in the Lexmark website on How to Clean the Print Cartridge Nozzles with the Lexmark X7350.
Mar 28, 2011 | Lexmark X7350 All-In-One InkJet Printer
Why is my print lighter and hard to read at the top of the page but subsequent copies look fine. thanks, gene
Your cartridges may need to be cleaned. Follow the instructions in this article from the Lexmark website on How to Clean the Cartridges of the Lexmark Z715 in Windows. This will help improve the print quality for your printer. Also, make sure you are using genuine Lexmark cartridges. Thanks.
Feb 24, 2011 | Lexmark Z715 InkJet Printer
I'm getting a a message that says "Left Cartridge
You can try to do the Clean Cartridge function on your printer. While on Copy mode, press Menu -> Tools -> Maintenance -> Clean Cartridges. You can try to insert a known working cartridge to determine if the other is faulty. If your original Lexmark cartridge is faulty, please contact Lexmark technical support and have it replaced. Thanks.
Feb 16, 2011 | Lexmark X5470 All-In-One InkJet Printer
I bought a Cheaper replacement cartridge put it in the printer and the printer says Error#1203 and cartridge error the cartridge is exactly the same as the Lexmark so what is the problem? My printer is...
Hello. The error has something to do with the cartridges. It might be not seated properly, needs cleaning or just low in quality. You can try cleaning the nozzles of the cartridges using a damp paper towel. But, I believe the printer will have its optimum performance when using genuine Lexmark ink cartridges. Good luck!
Mar 23, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark X-4270 all in one won't copy
try cleaning the heads with the fix on the printer help screen.go to-- help--type in printer copier won't copy- look for how to clean the heads of the ink pores. or try align cartridges. when you install new printe ink or the cartridges come with the machine you have to aline to keep the ink flowing right.
Oct 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X8350
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Aug 03, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X654de MFP All-In-One Laser Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
