Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric II
I have a Selectric II that has not been used in roughly 10 years.  It turns on and the carriage strikes a few times and moves to the left.  However, there is no response when I press the keys.  I've fixed quite a few manual typewriters, but I'm at a loss with all the electric components.  Any suggestions?
Thanks,  Lee
  • 2 more comments
  • Peggy Bryant Russell
    Peggy Bryant Russell Jun 15, 2008
    when you turn on the selectric typewriter the space bar works but the other keys there is no response. Any ideas what could be wrong? It is a Selectric II correcting typewriter.
  • timhoush Jun 23, 2008
    I have a whilwriter 5 it was working just fine, I corrected a word and it stopped printing, everything is working but it will not strike, did I put it into a code?
  • Anonymous Jun 25, 2008
    I also have a Selectric II correcting typewriter and the keys on it are stuck/froze - I'm thinking it may need to be cleaned.....but it was working ok before it locked up. do you think it could be anything else besides needing a good cleaning?
  • Anonymous Nov 06, 2008
    IBS Selectric III: When the room temperature is cool (60 degrees), and I use the correction key, it removes the error, however, the carriage then will not move. I take a hair dryer and direct warm air toward the carriage, which commences to function after a moment or two of directing the warm air on it. What might the problem be ... and how might I easily remedy it?
    Robert
Can I clean and lubricate it myself or do I have to pay someone
Posted on Sep 25, 2008
    New Friend:
  • 120 Answers
Yes. From not being used in so long It needs a chemical cleaning or washout and lubrication. It may need a part or two also. Everything is gummed up. I have been repairing selectrics for 35 years. Lawrence
Posted on Apr 23, 2008
    Problem Solver:
  • 14 Answers
Mr fixall is right. The grease in the machine gets clogged with dirt, and goes hard in cold weather. It will have to be washed out and regreased by an IBM trained tech
Posted on Oct 15, 2009
Paper won't feed.
Typehead won't move across paper.
Just bought on E-Bay; feeling somewhat abused.
Posted on May 15, 2008
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
I have an IBM Selectric III. When I initially
Try putting some WD40 on the silver shaft that the carrier slides on and also lube the pulleys in both ends.
DickyO
Mar 10, 2010 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Selectrik II sat for years. No escapt to next space after typing a letter or number
Be sure to put WD40 on the escapement (under the platen and paper tray) and the escapement drive mech. (rt. rear of machine) and the correction latching mech (under the rt. dust cover).
DickyO
May 31, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 15 Series II Typewriter Logo
1,388 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
