SOURCE: cooling fan on a8v-vm se
The whole colling speed is set properly within the computer so I wouldn't go adjusting that. You could get a different fan similar to the one thats in it, that may be a bit quiter.
Take it to the computer shop and show him them one you thats in it, that is on condition that you are confident about taking it out and putting on a new one in its place.
Make sure you are grounded when you open the computer and wear an ESD (Electo Static Discharge) strap or something. Especially when you are going near the motherboard.
SOURCE: Cooling fan running constantly.
the cooling fins are clogged, u need to get a small vacum and clean the area
SOURCE: my radiator cooling fan keeps on running and it
sounds like a stuck relay, relays can sometimes weld themselves closed
SOURCE: peugeot 306 diesel red stop light is on and both fans run
there are 2 relays inbetween the 2 fans behind the front grill the wiring to the relays tend to corrode.
what you need to do is replace both relays and the wiring conectors
SOURCE: Fan blower started running full speed, ...
THE FAN BLOWER RELAY IN STUCK CLOSE POSITION.YOU HAVE TO REPLACE FAN BLOWER RELAY.
