I will be using my laptop and all of a sudden, the monitor will blank out. I have to turn the computer off and back on again before it will come back on. What could be causing this?
  • kbr048 Apr 20, 2008
    I have a Toshiba Satellite A215-S7422. I received it as a Christmas gift this past December.
    Problem Solver:
  • 95 Answers
What kind of laptop and how old is it? Some laptops will shut the monitor off if the system gets overheated.
Posted on Apr 20, 2008
  • Bill Scarberry Apr 20, 2008
    Do you have good ventilation under the laptop while it is running? My Compaq presario R4025US will just shut off if the ventilation isn't good and it gets too hot, where my Dell Insperion 1100 shuts the monitor down. I would say to watch the heat, maybe watch the cpu usage and make sure its not staying at 100% Laptops hate running at 100% and do wierd things. Of course if it is running at 100% while you are doing nothing but surfing the web/ checking email etc you may have malware or a virus. make sure your windows is up to date and your antivirus software as well.
My laptop monitor was blank during i click sleep mode then it will not open again
YOU WILL HAVE TO MANUALLY TURN YOUR COMPUTER BACK ON USING THE POWER BUTTON!
HOPE THIS HELPS!
Aug 31, 2011 | HP Pavilion dv4000 Notebook
Why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
May 07, 2011 | ASUS LCD Monitor
My Hp530 is on but the screen is blank
This problem happened to a lot of laptop users,
Mostly it is a graphics card driver problem, i suggest that you press F8 while starting up and choose safe mode, then when start up uninstall your graphics driver and use windows standard vga driver, until you find another driver
Feb 01, 2010 | HP Computers & Internet
Screen blanks out after a few seconds. If I turn
Fixya:
My IE 8 loads the correct odds on the tote-board and then suddenly the odds go blank.
I have to click down to another track and then click back up to get the odds working again.
The issue happens again at another track that I click on. Forces me to go through the same proccess over again.
This bug related issue is very aggravating so if there is a fix I would appreciate it.
oppusone
My IE 8 loads the correct odds on the tote-board and then suddenlly the odds go blank.
oppusone
oppusone
oppusone
Aug 31, 2009 | AOC LM720 17" Flat Panel LCD Monitor
My pc monitor keeps going off and when the computer boots up it beeps and the monitor wont turn on properly . however the monitor works fine when attached to another laptop computer. does this mean the...
Yep, problem is with the video card. If it's a desktop you can pull the video card out and install reseat it back into the motherboard to see if that fixes the problem.
Let me know.
Feb 23, 2009 | HP Compaq Presario V2000 Notebook
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
LG L194WT Monitor suddenly stop working
it is probably indicative of a switched mode powersupply trying to start then seeing a short and then trying to start again...this will cycle continuously until fault is rectified..any component that can drain the powersupply is the culprit...you need some way of detaching the powersupply from the load (monitor) to see if the power supply its self is the cause and also check if there is a loop back (a pulse) for continuous running.
qube
Jun 06, 2008 | LG Flatron 563LE 15.1" LCD Monitor
Laptop just went blank...cannot power up or turn on
try by resiting the ram, if the problem persits than your display adapter is having problem
May 19, 2008 | HP Compaq Presario V2000 Notebook
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Apr 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
