Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer stopped running on spin cycle at this time my wife and I caught a smell of burnt belt, if this is the case and it's not the trans, how would we proceed to gain access and fix the belt.
  • 1 more comment
  • SpiralJacobs Apr 22, 2008
    In a strange coincidence, the same exact thing happened to our washer today, with the burning smell and all. Our basket only spins clockwise. Oddly, it will spin if there's no laundry in it.
  • giolene Apr 30, 2008
    The washer stopped working, once it filled the washer with water it stops. We first tired fixing the timer.
  • kfowler Jun 30, 2008
    No, it only spins counterclockwise.
  • 1,314 Answers
First thing to do is grab the spin tub and let me know if it spins both ways freely
Posted on Apr 20, 2008
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
Aug 08, 2012 | Maytag HAV3460AWW Top Load Washer
My washer started smoking and smelling like burnt rubber during the spin cycle what needs to be fixed
Sounds as if your belt burnt up. Could be a bearing froze up or your belt broke and got caught on the pulley. You will have to look inside the machine from the back to see what it is. If the drum does not spin by hand easily it is probably the bearings
Feb 10, 2010 | Washing Machines
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Maytag washer will not spin, clutch slipping
Sound like it's time to go shopping, sorry
Jun 20, 2009 | Washing Machines
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Performa washer smoking and smell of burnt plastic
It could be the pump or the motor overheating.
Remove rear panel, and run washer through a rinse and spin cycle.
After it has finished, unplug the washer, and feel the pump and the motor, they should be relatively cool to the touch.
If either the motor or pump feel hot, then that is probably the cause of the problem.
Also check for a worn or slipping drive belt.
Please rate my fixya solution.
Feb 09, 2009 | Maytag Washing Machines
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
167 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
