Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
My Frigidaire dishwasher does not seem to be "heating up". Have tried turning up the temp on water heater but it did not help.
  • Frigidaire Master
  • 43,501 Answers
Check your heating element..
DishwasherMy Frigidaire dishwasher does not seem to be - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jul 19, 2010
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag dishwasher MDB6160AWB "Clean" indicator
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Maytag Dishwasher
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool dishwasher ''clean'' light is blinking. The ''cancel'' button does not reset the cycle. We don't know how to wash/dry our dishes. We tried the diagnostics but...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 09, 2011 | Dishwashers
Won't turn on. "Clean" button is flashing.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 24, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Kitchenaid dishwasher....clean light will not turn off. Dishwasher will not turn on. Just had motor and pump replaced on Thursday 12-30.
Hi
If clean light is blinking indicates an issue with heater circuit, door switch or wash pump. To resolve this please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
Daniel
Jan 01, 2011 | KitchenAid Dishwashers
The clean light won't go off on my Frigidaire 1000 series dishwasher and the only way to make it run or work or do anything is to reset the breaker. I have tried everything. PLEASE help
Hi
Daniel
Nov 27, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Dishwasher runs for 3 hours
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
Aug 14, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Water not very hot
Yes there is a heater in the dishwasher, but I am suprised it goes through the cycle if it is not heating. for this reason I would suspect that it is a thermostat problem. these are situated underneath the machine. you will need a test meter, to have an engineer do this repair it should cost no more than 70 pound.
Dec 03, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
98 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
