Question about Honeywell Heating & Cooling
My heating and cooling message is flashing the following message LO bREE and I cannot get it to work - what does this mean and what do I need to do?
  • 532 Answers
Please, use the manual to check the meaning of the message.
If you do not have the manual use the model of the air condition to download the manual online.
Thanks for contacting Fixya.
Posted on Jul 15, 2010
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
My portable air conditioner stops blowing cool air after a while and the light is flashing with a sign "lo" Does anyone know what this means?
Flashing lights are generally a sign of something wrong or something needs attention. Try emptying the water canister, cleaning the filters etc.. Not sure what LO means on your model. LO on some wall mounted splits means that the room temperature is below what the remote control can pick up.
Jul 03, 2011 | Heating & Cooling
Whenever i put on my laptop, there is message that reads "system has detected that there is a cooling fan that is not working well" what does dis mean, and wat do i do about it?
the fan is running too slow...............over heating will follow. strip lappy down and remove all dust from fans and heat sink fins. ............
cheers
Mar 26, 2011 | HP Computers & Internet
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
Hi my Harmon satellite 750 keeps flashing LO new batteries and power plugged in what does this mean
unplug the the power plug from side of radio and radio will switch to battery power,i had same LO message on my eton 750 but this stopped it
Oct 22, 2010 | Eton Satellit 750 AMFMSW Radio
Even thuogh I made sure it was not on economy mode my hot tub will not heat up and the message board keeps flashing the word cool, do you know what could cause this?
it may be a bad temperature sensor or a bad heating element. Sounds more like a heating element. The cool should just be a warning or depending on the model, could mean that it thinks the water is too hot and is in "cool" mode trying to cool the water. Have the temp sensor and the heating element checked.
Feb 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jeff
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
Bel 980 problem
I have the same thing wrong with mine ! I put it in my other car and it works fine. Found out it was my alternater was not working right! Hope this works for you
Nov 08, 2007 | BEL 980 Radar Detector
Heating & Cooling Logo
109 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
