Question about Konica Minolta magicolor 2300DL Laser Printer
I'm getting a media jam transfer roller on my magicolor 2300 dl how can i fix it
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Media jam transfer roller
directly below the drum ensure transfer roller properly installed also check the drum unit
Jan 08, 2014 | Konica Minolta magicolor 2430 DL Laser...
Paper Jam at Tray 1
The solenoid may be getting stuck, the only way to check is to remove the solenoid and check that it opens and closes smoothely.
May 26, 2013 | Minolta magicolor 2300W Laser Printer
Media jam tray 1
Here are a couple of links from the Konica website which provide somes illustrated instructions:
Media Jam Tray 1; Paper Pickup Roller replacement instructions.
Clearing Media Jams
Replacing the pickup rollers seems like a drastic first step. I would check to make sure that the paper being used is suitable for this printer and it is in good consition. You might try a different paper to see if it makes a difference.
Good luck in resolving your issue.
Dec 30, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Media jam, transfer roller
Replace the offending transfer roller.
Dec 20, 2009 | Konica Minolta magicolor 2300DL Laser...
Minolta QMS 2300dl
fix your cartridge again to its position .
also check there is not any paper jam.
open back side case of printer then check thee is not any papaper jam.
Nov 01, 2008 | Konica Minolta magicolor 2300DL Laser...
I get a Media Jam Message
Hey folks! This solution worked for my "media jam tray 1" problem! Just took out paper, pushed down @ back of tray, reloaded paper, and bingo! Now to use some air to blow out any dust.
Thank you
Mar 23, 2008 | Konica Minolta magicolor 2300DL Laser...
We have a Xerox 6120 which is mechanically identical to the 2430. It was reporting media jams. We determined after removal and careful inspection that the fuser roller and fuser pressure roller had been damaged by what looked like someone attempting to clear a jam with a sharp object. I cannot speak re: the 2430, but the fuser in the 6120 is not a FRU. The construction of the fuser doesn't tolerate any flaws on either surface. There was more paper jammed in the fuser where we couldn't see it until we had the fuser out of the printer. We are shopping for a new printer as the repairs will cost more than we paid for the printer.
Dec 10, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
296 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
