Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
White smoke coming out of mower
My craftsman riding mower runs fine until you engage the blades. It will mow for awhile then start to die and white smoke comes out of it. Can you help?
  • DOCHOLLIDAYDDS
    DOCHOLLIDAYDDS May 02, 2016
    I know this is late, but reviewing several problems..... remember, excess gas burns black, oil burns white. Probably bad rings on the piston
  • 420 Answers
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Posted on Jul 16, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have a craftsman mower model no 917.28922 that blows blue smoke after engaging blade and is using oil..maintained and kept very clean after every use...what should I check, has new spark plug.
If your maintenance did not include changing oil each season that made the engine wear out sooner. Clean on the outside does not help the inside. You can get a price on rebuilding the engine but I have a feeling that you can replace the mower for not much more. Use it till it dies if you plan to replace it.
Feb 14, 2015 | Craftsman Garden
Why does unit run sluggish when blades are engaged?
if you are talking about before even moving, it could be grass and dirt caked inside of the deck. If you are talking about when you start mowing, it could be front to back height adjustment. owners manual has instructions for adjusting deck height.
Jul 24, 2014 | Craftsman Garden
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
When I lower the mowing deck on my Murray 17.5hp riding mower white smoke pours out and it dies. The engine runs fine until the deck is lowered.
Does it make a squealing noise then too? The white smoke is probably a belt burning up. Either you have a locked up blade spindle, or the belt is off, and rubbing. Check the deck belt(s) and the clutch assembly.
Aug 02, 2010 | Garden
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,218 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
