Question about Craftsman Garden
Drive belt is too loose, already replaced belt and pulley. no drive power, plenty of deck power. Tractor is 8-10 years old, drive pulley portion of the double engine pulley split, so I replaced it and the drive belt. I can't make it up hills without a load that I used to , never mind pulling anything. Is there an adjustment? I tried pulling on the long spring (#55), but extra tension didn't seem to tighten the belt. (I was going to replace it.) Craftsman Model TRACTOR - 917258591
  • 1 more comment
  • rickhan Nov 18, 2010
    Didn't see any build up, so I looked further. Turned out that the rear pully on the transaxle was worn out -- I should have replaced it when I replaced the front one.
    I also replaced the tension spring. The old one was stretched compared to the new one. Easy to replace if you run a long, heavy wire through the chassi and stretch the spring that way.
  • Anonymous Mar 16, 2014
    I have lost drive and can't see how to access the drive belt pulleys to inspect or replace the belt
  • rickhan May 26, 2014
    Also, if you pull heavy loads, especially on hills, you will wear our your transaxle. They can be rebuilt or replaced. They really aren't heavy duty in this model. The current yard tractor has a transmission twice as powerful, or more.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
I had the same problem with my Craftsman Lawn Tractor. The Drive Belt (which is not adjustable) is only engaged when the Brake Pedal is released (the Brake Pedal is located on the left side of the tractor, near the foot rest on my Tractor).
The Symptoms: My Tractor lacked driving power, and would not go up an incline, but the mower deck was powerful and working fine, even though the Tractor seemed to lack power and moved slower than usual, and would not travel up an incline.
I too, changed the Drive Belt, which initially seemed to help somewhat for a very short period of time, and then the same, lack of power problem, re-appeared again. The belt was not the problem, but only seemed to work somewhat due to the rougher texture of the belt's surface against the pulleys.
I also changed the Plastic Clutch Pulleys that engage the Drive Belt, thinking that they may have been worn down to a point that the Drive Belt could not fully engage with these Pulleys. No Luck.
NO ONE, NOT EVEN SEARS ON-LINE REPAIR ADVICE CENTER HAD A SOLUTION. THIS WAS VERY FRUSTRATING INDEED.
There had to be a solution: After much investigation, I eventually discovered the problem, which actually was easy to solve, and I would like to share this simple solution with others facing this same Frustrating Problem.
The Brake Pedal, when released, causes the Drive Belt Clutch Pulleys to move, and thus Tighten the Drive Belt. When you look under the Tractor, there is a Protective Metal Plate mounted to the Bottom of the Main Tractor Frame which covers the Brake Pedal Shaft and attached Mechanisms. Over time, Grass Builds up in between the Protective Metal Plate and the Tractor's Main Frame Deck, creating a very narrow space between these two pieces of metal.
This area is very difficult to get at, and almost impossible to clean out. Over time, Grass Clippings accumulate in this hidden area, and harden to an almost rock hard clump.
These Hardened Clippings accumulated between the Brake Pedal Mechanism and its fully released metal stop position. Thus, preventing the Brake Pedal Mechanism from moving to its fully engaged position.
I used a long screw driver to break up the compacted grass clippings, and an Air Compressor Blow Gun to break up the packed grass and blow the area clear. It takes awhile to do this cleanup, and is a bit messy, so do it outside, but be patient, and be sure to clean out all the grass that is lodged in this hidden area.
What was happening was that the Packed Grass was so dense that the Brake Pedal could not Fully Release, thus only Partially Engaging the Clutch Pulleys and the Drive Belt, hence the appearance of a loose Drive Belt even when the Brake Pedal was released.
Once the Packed Grass Debris was cleaned out, you will immediately notice the Drive Belt being tighter than it was previously when the Brake Pedal is released, and when you test drive the Tractor you'll find that everything works perfectly, like it was brand new.
Good Luck...
Rayko
Posted on Nov 15, 2010
    Couldn't find any build up in mine, so I looked further. Turns out the rear pulley on top of the transaxle was very worn--I should have replaced it when I replaced the front one.
    I also replaced the tension spring. The old one was very stretched compared to the new one. It was easy to install if you stetch the spring by threading a heavy wire through the chassi.
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
My lt1000 craftsman riding mower belt broke. I bought a new one and can not seem to find the manual to see how to replace it. Can you show me a diagram please?
On your mower, lift up the seat and you will find a silver sticker with numbers on it. There is a 9 or 10 digit model number. It will look like 123.456789 Go to www.searspartsdirect.com and input your model number and perform a "model" search. I am assuming that the belt you are referring to is the deck belt. Go to the deck section and you will see a basic pattern of what shape the belt will have when installed. There are 2 kinds of pulleys on your deck...V-groove & flat side. The v-groove pulleys go on the inside of the belt, the flat side will go on the outside of the belt.
If the mower is more than 3 or 4 years, it is probably a good idea to replace the drive belt(s) also.
Good luck.
Oct 22, 2010 | Craftsman Replacement Belt for 42" Deck
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
JD mower L110, hydro drive. Reverse power is low.
i have the same thing a tractor shop told me thats ok they are slowed dowm for saftey
Nov 01, 2009 | Garden
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt diagram
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
This is the most common belt to replace
idle pulley (x)
lx tension pulley
/ l_______
the deck running belt left deck (X ________________ ____ x)
Apr 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt jumped off pullies
l l
l l
l l -
back deck pulley =x
Apr 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Primary v-belt , mower , on gth2548 keeps tearing/chunking out
I have a CTH2542 which has a 42" cutting deck. I bought this from new and it's now aprox 8 mths old. I observed slippage problems with the machine after about 3 months, and being a diesel mechanic myself, dropped the cutting deck off and checked the drive belt. It appeared to be an 'A' section belt which means it should be of 1/2" (12.7mm) section. Measurement revealed it had worn 1mm and was bottoming out on the drive pulley at the motor. Once any vee belt (or pulley for that matter) wears to this point it must be replaced as it WILL NOT grip the sheaves of the pulley. I had my local service agent look at it, but they say they could find nothing wrong. I investigated the problem further and to my surprise, I discovered the swinging (spring loaded) belt tensioner has been positioned on the loaded side of the vee belt. Therefore the more load that's placed on the drive, the more the tensioner is pushed aside, and the looser the drive belt becomes. I have re-jigged the drive setup on my machine (it was suprising easy once I'd figured out what to do). Now, if I **** the bull bar of the machine against my Ford tractor tyre, and load the hydraulic transmission, the rear wheels will actually spin - it wouldn't do that before. The reason I investigated this problem so thoroughly was because I went to buy a replacement vee belt for the machine and was told 'Husqvana tractors for some reason munch up standard vee belts - you must use the genuine belt which is kevlar based'
regards
Mike Clarke
Hamilton
New Zealand
Jan 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
1,045 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
