Question about Samsung S1030 Digital Camera
Low Battery When turning the camera on, the screen often says "Low Battery", even if the batteries are brand new. The problems seems to last a few hours, then it turns on as normal. I have tried cleaning the contacts and the battery tubes, but nothing obvious seems to cause it, or solve it. Sometimes, it cuts out to "Low Battery" in the middle of taking photos, when the charge indicator on the screen has just been at full. Someone else asked this question on-line, but had no replies, and a friends camera (S series, but not the 1030) does exactly the same thing. Any suggestions. Many thanks
  • Samsung Master
  • 19,396 Answers
Try going to a service shop and asking to reinstall the firmware, this can fix the problem
Posted on Apr 20, 2008
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
My battery is constatly low. the battery can last for a few hours and then phone turns off. i tryed to buy a new one, but it seems to be even worst.
Hello
Is your phone charging, if it is charging, no problem.
The problem with your phone could be virus problem because virus runs battery down.
The second place to look at is the battery terminal of your phone, It is possible that the battery terminals are corrode, If the are, it will definitely keep running the battery down.
Look at these two areas with care and your problem could be solved.
Take care.
Apr 19, 2010 | Samsung SGH-D600 Cellular Phone
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Mar 01, 2009 | Nikon D80 Digital Camera with 18-200mm...
No battery life
If you have changed to new batteries and it still shows low battery warning, the camera may need the repair service.
Here is the information from Canon's support page.
Batteries do not last very long in camera (You will need to copy and paste the title on the search field)
"Solution: The PowerShot A550 requires service.
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below: ..."
Jul 10, 2008 | Canon PowerShot A550 Digital Camera
Samsung S1030 Digital Camera Logo
91 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
