Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
The drive was erased and now my computer doesn't recognize it
  • 10,319 Answers
If you ran the job FORMAT the hard drive is totally blank. It will not recognized nothing you try and install until it is partitioned
Posted on Jul 15, 2010
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Computer doesn't recognize internal drive installing vista
Drive 0 means that it is the first (or only) drive plugged in. You should use a partition manager to format the hard drive to give it a partition. After you have a partition made (NTFS format) it should show up!
Nov 04, 2012 | Computers & Internet
Flash drive doesn t work
if the flash drive doesn't recognize try to insert it to other device or computer to test the condition of your flash drive if bad change it..
Jan 03, 2012 | LG Televison & Video
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My mac does not recognize my seagate goflex drive anymore
Try the drive on another computer. If it is recognized there, you might be looking at a larger issue on your Mac. If it doesn't, the GoFlex's drive or boards may have failed.
Jul 07, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
LG DVD-ROM 8160B
If I understand this correctly, you erased a cd of data and want it restored?
If this is true, then I am sorry to tell you that you will not be able to get that cd data back.
Dec 17, 2008 | LG DRD-8160BB (GDR8161BBGDR8162BB) Burner
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
120 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
