Can you bypass high pressure transducer on a york chiller model ycas250 air cooled
  • 57 Answers
No you cannot
Posted on Jul 16, 2010
I have low suction pressure problem on YCAV187 York Chiller.
How's the sight glass? Possible blockage?? Expansion valve opening and closing???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 20, 2017 | Heating & Cooling
York chiller YDAJ model chiller compressor trips in low oil pressure after running for sometime. To solve it i changed the oil & the oil transducer but still tripping what can i do
You could be light on charge or the oil pump is failing. There may be a delay setting that is set incorrectly. I see that with several 507 systems.
Nov 29, 2014 | Air Tools & Compressors
I need information ary model chiller fault,low water temperature
Hi,your question is not very clear though.
1Try to check the chilled water sensor(transducer for appropriate resistive values).
2.Check that chilled water is circulating at the correct pressure
Regards,
Adamson (nyauadamson@gmail.com)
May 04, 2014 | Heating & Cooling
30GXmanual chiller
replace the oil pressure transducer with a new one!
Aug 28, 2013 | Carrier Refrigerators
My vehicle's a/c compressor will not kick on, so there is not any cold air. when a current is applied directly to the compressor, it kicks on nice cold air. There is something preventing the current...
the vehicle is equipped with a pressure transducer. the pressure transducer relays info to the ECM to turn the compressor on, the cooling fans on by letting the ECM know how much pressure is in the lines. the problem is it can go bad and show high pressure (over 4 volts) to the ECM and not allow the a/c to work.
Aug 04, 2011 | 1999 Chrysler 300M
Our york MAXE screw chiller tripped on CONDENCER-HIGH PRESSURE-STOPPED when i want to reset means it asks password,what is the password
My chiller was high pressure trip and i cannot reset the fault using 9675 and 1380 passcode! What should i do ?
Nov 24, 2010 | York Yankees Bedding MLB Comforter
York 3phase compressor tripping on low currant microprocessor.
If the unit is single phasing this is not good for the compressor. Does the system have a phase monitor? If not I would suggest you put one in to save thousands of dollars on the replacement of the compressor. How is the oil level? I ask because this are not to run themselves out of oil.
Jan 12, 2010 | Mastercool 67471 Evaporative Cooler Air...
High presure rest on robinair 34788
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robinair 34788 machine having same problem.You can try the following 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Aug 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
