Question about Garmin nuvi 200W GPS Receiver
My garmin won't stop searching for a satellite. It shouldn't take this long to acquire the connection, and we've been moving in areas where we've used it before. I've tried restarting it, re-inputting the address, but nothing is working. Help!
SOURCE: Garmin eTrex Legend
If it hasn't been used in a long time it could take up to 30 minutes to get positioning. Get a clear view of the sky and let it set at least 30 minutes. If that doesn't work antennae connection is bad. Its not a software issue.
Posted on Nov 23, 2007
  • 12 Answers
SOURCE: won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Posted on Dec 09, 2007
  • 35 Answers
SOURCE: Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Posted on Jan 21, 2008
SOURCE: Garmin NUVI 650 acquiring satellites
  • Make Sure the GPS has a good, clear view of the sky. “Clear” does not need to be sunny. Overcast skies have no noticeable impact on GPS performance. But buildings and trees do. So take the GPS outside where you have the biggest sky view as you can.
  • Next, wait for the GPS to acquire a signal. If this is the first time you have used it, expect it to take up to 20 minutes to find a signal. Most often it will take less, but prepare for 20 minute. Now for an important step… Once it has found your location, let it continue to sit there for about 30 minutes.
Posted on Jan 12, 2009
  • 171 Answers
SOURCE: battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
Posted on May 09, 2009
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
The problem might be that your GPS is not able to connect to the satellite.
I'll see what the problem might be.
Mar 15, 2008 | Garmin nuvi 350 GPS Receiver
My garmin nuvi 1450 repeatedly says "acquiring satellites". How do I fix this?
Take it into an open area such as a parking lot or field, it will soon acquire the satellites and they will stay acquire unless you go into a parking garage.
Jul 26, 2011 | Garmin nuvi 1450 GPS Receiver
My garmin quest is constantly searching for satellites, but it never acquires them.
If you are in any open area it should acquire a satellite almost immediately or in less than a minute. I suggest you contact Garmin to have it sent in for repairs. Garmin's website is www.garmin.com go to the top right of the webpage and click on My Garmin. If your already registered on the website then put in your info if not then create an account. After that look up support and either call Garmin or Email Garmin for repairs.
I hope this helps you out if it does please give me a Yes on the page you are reading this response on. Thank you.
Apr 06, 2011 | Garmin GPS
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Unable to get satellite reception
Make sure you are not moving and that you are on an open field with minimal aerial hindrances. It takes time for the GPS unit to acquire satellite signal and makes it difficult to acquire when you are moving so make sure you stop at an open are till it syncs with at least 3 satellites.
hope this helps!
-levibit-
Mar 20, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
110 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
