Question about Durabrand Portable DVD
Durabrand pvs 1970 stuck on standby .plug it in a car and ac adapters and the standby on the unit is lite. not able to play
  • Arthur Peloso
    Arthur Peloso Jul 15, 2010
    durabrand pvs 1970 stuck on standby .plug it in a car and ac adapters and the standby on the unit is lite. not able to play
  • Arthur Peloso
  • 3,866 Answers
This stanby light is when the unit is powered but not turned on, if its stuck in stanby try taking out the battery then using the car adpator to turn it in if it does not turn on then, you have a defect in the unit going ot need repair, however if it does turn on then what yo need to do is replace the battery as that is what causes this fault is when the battery gets so low that it cannot be charged anymore.
let me know ether way
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 15, 2010
  • 484 Answers
The power from the source is reaching the durabrand pvs 1970 but the problem is from the main board of the duraband.
A capacitor on the main board is burnt and the best solution is for you to have a repairman change the capacitor of the durabrand pvs 1970 and you pvs would be in good condition again.
There are several capacitors on the board, therefore, you should have the capacitors tested before replacing the worn out capacitor.
Take care
  • 7 more comments
  • Arthur Peloso
    would this be in the power supply and is it a electralic cap.
  • ladipo sarumi
    ladipo sarumi Jul 15, 2010
    The power is reaching the duraband but the power is not reaching the main board, simply because the capacitor is not reading the power that is being supplied to the duraband.
    Have a repairman check the capacitor on the board to correct the error.
    Mostly capacitors need replacement.
    Have the capacitor replaced and your duraband pvs will be okay once again.
    Take care
  • ladipo sarumi
    Yes, it is an electric cap.
  • ladipo sarumi
    It is in the power supply and it is an electralic cap.
  • Arthur Peloso
    you did not answer my ? I don't nee d a repair person i am experence to do it my self i'm try to get all the info from some who had this same problem
  • ladipo sarumi
    The problem is simply from the power supply.it is not reaching the main board, and the problem is from the power supply panel.
    Check the capacitors on it to see if they are flat.
    Take care
  • ladipo sarumi
    I did not know you can handle this yourself. I felt it was technical and required the hands of an expert.
    To fix this, open up the duraband, access the capacitors on the power panel to see if it is flat, if not, it means you have a bad capacitor.
    Get the panel off the case, turn to the back and try to use a pin tip soldering iron to soldering iron to melt the lead that is holding the capacitor down and replace it with a new capacitor.
    Place the panel back in the case and reassemble it back together.
    Then you can plug it to a power supply and power it on.
    Ensure it is not being exposed to a very high current.
    I think this will do the work.
    Take care
  • Arthur Peloso
    thank i'll take it apart now
    art
  • ladipo sarumi
    You are welcome. Also please do not forget to rate this after working on it.
    Good luck.
    And be very careful with the panel as you and i know its very sensitive.
  • 6,993 Answers
this is power related problem. Remove the battery from he durabrand and fix it back it. This might put it back in order. If it doesn't, please let me know.
Take care.
  • Arthur Peloso
    the unit does not have a battery this is mobile unit for cars the model is duraband pvs 1970
I have a Durabrand PVS 1970 and I need a monitor cord for it. Mine has a short in it. Any ideas where I could find one?
if you are talking with an audio/video cord you can find it at amazon or ebay or wallmart....thank you.
Jun 06, 2012 | Durabrand Televison & Video
Plug is broken
You can buy a new Durabrand Dual car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand Dual 7b portable dvd player
You can buy a new Durabrand Dual wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for DURABRAND Dual 7b PORTABLE DVD PLAYER
Jun 20, 2009 | Durabrand Portable DVD
I have a PVS 1970 portable dvd player w 2 screen for our car
First, If you have a video IN/OUT switch make sure you have video OUT selected. If you have a blank but lite screen, then your display screen is bad. If you have a dark screen, you should be able to look closely and you might see an image, if so then your backlite might be out. Also make sure not to try to power dual screens with a battery. Make sure the adapter is propery rated for proper output voltage. If repair is needed, you contact me through ebay messaging. Search ebay seller " richards_resale". Good Luck!
Dec 13, 2008 | Durabrand DUR7 Portable DVD Player
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Cord missing
http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Apr 15, 2008 | kawasaki PVS1965 Portable DVD Player
How do I charge battery
Simply hook the battery up to the player, plug in the adapter (house AC outlet, car adapter will not recharge batter), and turn the unit off.
The charging light should come on and when it goes out it's fully charged.
Jan 18, 2008 | Durabrand Portable DVD
Durabrand PVS 1970 portable DVD player
I have a PVS-1970, and it does not have a battery. It is for use in the car or in the house. It MUST be plugged in to a power source - NO BATTERY!
Aug 01, 2007 | Durabrand PVS1966 Portable DVD Player
Durabrand Portable DVD Logo
191 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
