Question about Amana SXD524VW Side by Side Refrigerator
JUST THIS MORNING NOTICED WATER LEAKING FROM ICE MACHINE. AFTER CHECKING THINGS OUT LOOKS LIKE NEITHER REF OR FREEZER ARE COOLING, THE FAN IS RUNNING ? PLEASE & THANKS
    President:
  • 1,796 Answers
Hi!!
Most likely the evaporator in the back of the freezer, behind the fan, is all iced up. You need to unplug the fridge and let it defrost, you can remove the cover and use a heat gun or hair drier to make defrosting faster.
Once it is defrosted, plug unit back on and lower the freezer temp. by one click.
Don't forget to rate this post. Good Luck!!
Posted on Jul 15, 2010
Our ice maker is making ice in big clumps. There is a small white little thing that looks like a thermometer hanging on a white wire that I have never seen before and do not know where it goes. The ice has...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 23, 2011 | Samsung Refrigerators
I noticed last night water would not come out of the dispenser, this morning liquids in the fridge part were starting to freeze, I turned the temp dial down to not so cold ( it has never been adjusted for...
NOTE: This
Leo Ponder
imufo2
Sep 21, 2011 | Amana 22.6 cu. ft. Side-By-Side...
My subzero 650/F is not making ice. I cleaned out the refrigerator and freezer. I noticed white switches above the white ice tray and an arm. What should I be looking for to check? Thanks.
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Sep 06, 2011 | Sub-Zero 650 / O Bottom Freezer...
Two days ago, the water stopped coming out of our side-by-side refrigerator. The next morning, the inside of the freezer looked like a frozen waterfall. We cleaned what were really dirty coils below the...
NOTE: This
I'm
Leo Ponder
imufo2
Aug 25, 2011 | Amana Refrigerators
I have a Kenmore side by side 596.57582790. Ice machine dispenser stopped working then a week later the water dispenser stopped. Pulled out the fridge to check to if there was a problem with the...
NOTE: This
I'm
Leo Ponder
imufo2
Aug 22, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi, I have an AEG S 75388 KG 6 The freezer is working okay but the fridge is running warm. I can hear a motor running intermittantly but don't know if that is the fan or the compressor (although the...
NOTE: This
I'm
Leo Ponder
imufo2
Aug 16, 2011 | AEG S75388KG Bottom Freezer Refrigerator
My Danby DKC645BLS is not cooling consistently it will run and run and never get below 50 degrees. The cooling fan is working properly. Please Help?
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 10, 2011 | Danby DKC645BLS Compact Beverage Cooler
Ice builds up in freezer than leaks out around seal
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 09, 2011 | Maytag Refrigerators
FRIGE JUST STOPPED WORKING NOT FREEZING AND THE REFRIGERATOR STOPPED COOLING. FREEZER ONLY BLOWING COOL AIR. THE NEXT DAY CAME HOME FROM WORK IN THE MORNING AND THE FREEZER IS BLOWING COLD AIR AND THE...
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 28, 2011 | LG LFX25960ST Stainless Steel French Door...
Freezer gets cold, Refrigerator Hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You can't see the door but, you should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system which consist of the defrost timer, heater, and thermo disc.
Also, If you replaced the evaporator fan then you got a good look at the cooling coils. Look at these coils while it is running. There should be a light coat of frost on all the coils. If this frost line is only 3/4 or 1/2 or any amount less than full coverage of the coils then the system has a coolant leak.
Directly under these coils is the drain pan and drain hole in the middle. This area should be clear of any ice or debris.
Dec 25, 2008 | Kenmore Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
81 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
