Question about Dell Optiplex GX280 (99301) Motherboard
Hd keeps rebooting. I swapped drives, battery, memory and still the same so it must be something with the motherboard. Any suggestion. It's a Dell Optiplex GX280 desktop
    Scholar:
  • 119 Answers
It could also be the processor, either its overheating or it has simply packed up first check that the heatsink above it has been correctly installed and is resting directly on top of the processor and that the fan on the heatsink is functioning. If that doesnt work then replace the processor completely.
Posted on Jul 15, 2010
I had the same problem. It was bad RAM module. At the bios setup, turn off Fast Boot at Post Behavior. This will check your memory more extensively.
Posted on Sep 16, 2010
Dell 2400 desktop pc will not turn on. Mother board flea led light does turn on.Tested power switch and wiring okay.I did swap power supply pack from a good working 2350 Dell pc same problem any...
Try to remove all components all drives (hard drives, cd/dvd roms, floppy drives, etc), all additional cards (modem, video card, sound card etc), remove the memory. Just leave the motheboard, proc and power supply. Before disconnecting everything completely discharge power by holding down the power button while the computer is unplug from the power. It should clear the flea light on the motherboard.
Test it again with just the motherboard, processor and the power supply. If still no power then most likely it is the motherboard since you already put a known good power supply. Motherboard has higher failure rate than the processor. You can swap a known good processor if there is.
Jul 25, 2011 | Computers & Internet
I have a Acer Aspire 6920. It keeps rebooting even while reinstalling Windows 7 or Vista ,Memory was change and hard drive same problem.
DEAR SIR,
WHEN MEMORY & HDD IS OK, PLS GET YOUR MOTHERBOARD CHECKED BY TECHNICIAN ,, SOMETHING IS ERIOSULY WRONG WITH CPU SUS SYSTEMS.. , GRAPHIC, MEMORY , STORAGE ALL SYSTEM SEEMS TO BE OK ..
Feb 10, 2011 | Computers & Internet
I have this motherboard and it won't post. The HD light stays on but does not appear to be spinning. I swapped HD's...same problem. I think the MB is bad. Any suggestions on what to check next?
If the mother board will not complete the POST, (Power On Self Test) changing the drive will have no effect. You might want to remove all memory and check again ... your memory could be causing the problem. Remove all boards and attachments except mouse, keys and monitor of course so you can see what is going on.
If it will not POST, get another board.
Basics ... always go back to basics.
Thanks for your interest in FixYa.com
May 31, 2010 | Intel D865GBF Motherboard
My pc shut down on me now we cant reboot it it say there is no hard drive
well is dead hd (normaly the final step of virus spreading), must be replaced.
Jan 16, 2010 | E-Machines eMachines Desktop PC
I just bought a used (or refurbished) MSI 845GE MAX MOTHERBOARD (478 pin, etc) and plugged in my Radeon 9550XL AGP 8x (4x compatible) card, (2) 512MB Sticks of Mushkin DDR2 (PC3200) RAM, Random IED HD, DVD...
Did you try another graphics card? If this motherboard does not have onboard graphics then try another card. AGP slots go bad sometimes too. I've had that happen.
Sep 18, 2009 | MSI 845GE Max-L Motherboard
Msi ms-6378 motherboard system freezes or reboots just after posting, somtimes windows will attempt to start-up but, the system just reboots again, I've swapped memory, hardrives, checked cmos battery,...
have u checked vga card take out all peripheral cards and all cd rom dvd rom drive cables just put RAM Hard disk and VGA on board then check it seems like hardware conflict pls let me know abt the results i can guide u further
Mar 08, 2009 | Computers & Internet
Acer Ferrari 3200 won't boot
Try different memory just to be sure its not that and if still no boot then its the motherboard.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
PC won't 4power on.
Failures in the motherboard, memory, or any installed card could cause that symptom. All I can suggest based on the above information is remove memory one piece at a time and retest, remove/reseat video card if you have one, and attempt to reset the CMOS using the jumper on the board. You might also try removing the battery on the board and unplugging everything, then attempt to reboot.
Jan 03, 2009 | Acer Aspire™ T180 PC Desktop
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
206 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
