Samsung SGH-U600 Cellular Phone Logo
Anonymous Posted on Jul 15, 2010
Phone wont switch on plus screen jumbled - Samsung SGH-U600 Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
41
Questions
0
Helped
10168
Points
48
The ribbon connecting your keypad to the screen is probably worn I have the same phone and replaced ribbon problem solved
Can I reset ti 83 plus
Remove all four AAA batteries. Press and hold the ON key for at least fifteen seconds. Replace the batteries.
My w995 wont text tidy all letters are jumbled when pressed
Hiya, you need to go into language and press the button T9, that button is an automatic text button so it needs to be turned off to text properly. Hope i was of some help to you, kind regards.
Nothing is displaying just white screen for last three days.Even before to that the display was not good i mean screen jumbling for model w395
  1. Try a scratch-remover product. These are available online and in retail locations. Apply a small amount of the cream to the screen, then rub it in until the scratches fade away.
  2. Apply pressure to the cell phone screen. Stuck pixels are another problem that can occur on a cell phone screen. They'll create discoloration in different areas of the phone. To fix this problem, rub at the discolored areas with a pen cap to disperse them on the screen.
  3. Fill any cracks or scratches with a small amount of toothpaste.
  4. Replace the cell phone screen. If the crack is severe, this may be your only option. You can search for your phone model and purchase a new screen through online stores. To make the replacement, use a screwdriver to pop off the old screen, then snap the new one into place. The process may vary depending on the model. When in doubt, take the phone to a cell phone repair shop to make the switch.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jan 17, 2011 • Cell Phones
When i turn on my ti-83 plus calculator, i have jumbled up things on the screen and i can only type half way on the calculator...when i put 2+3 it doesn't give me 5...when i press enter...it just goes down...
The Calculator need Os Update and Rom Reset and to clean the Ram
you need a Special cable and adaptor to fix this problem
if you want to fix this problem let me know
[email protected]
Jack
White screen on the display Can't see anything else except white screen. Front screen is a jumbled mess.
Your screen's wire in the phone was most likely diconnected from a fall or many falls. the front screen sounds like the same thing.
Jumbled screen on LG CU515
Your phone has a LCD (liquid crystal display) and if it is dropped or gets a chemical or even water on it it can damage the fragile insides of your phone. Is there a gas at the shelter that could be affecting it? Barring that, take it to your provider and have them analyze the problem. That is a free service. Good luck.
Canon powershot S400 LCD screen image jumbled
This sounds like it might be a defective CCD imager. This will get worse with time, and the pictures may be jumbled next. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
2answers
Vocopro Gig Man won't play
we're having probles.we have avhf-4800 from voco pro,lights come on the box and on mikes no sound on teo mikes
2answers
Outside screen
You need to take back up of your phone and master reset your phone. The problem will be solved.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
