Question about HP Office Equipment & Supplies
HP B209 a-m scanning problem
I have a puzzling scanning problem with my HP Photosmart Plus B209-a-m printer/scanner. I sometimes have occasion to scan both sides of postcards. I place the card in the corner of the glass as shown by the symbol. When I scan the front of the card with pictures on it and send it to the computer, the image I end up with fills screen – which is what I want. When I turn the card over and scan the side with handwriting on it and send it to the computer, the image I end up with is mostly white space with the card as a smaller image in the corner. I have read through the manual and fiddled with the help info on the printer itself but found nothing to help the problem. What do I have to do to always get a full screen image when I scan postcards? Thank you.
Riztech
  • 731 Answers
SOURCE: My scanner always scans with blurry lines across scanned images from it
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
Posted on Feb 09, 2008
SOURCE: I have a HP photosmart
I get this every now and then, usually because, during a scan, I abort for some reason--reset the computer, force-quit, whatever.  The printer driver, I think, leaves some breadcrumbs that it can't recover from when it runs again.
Anyway, I reset the printing system and install the latest HP driver.  If that doesn't work, I delete the HP folder in the Applications folder; then remove whatever files I can find in the /Library folder such as Application Support/Hewlett-Packard, Application Support/HP, any HP file in Preferences, Image Capture/TWAIN Data Sources/HPScanPro.ds.
Then reinstall the driver and things work fine.  I'm thinking this last item, the HPScanPro.ds in the TWAIN folder might be the culprit but I haven't tried just remove it alone--after I remove everything things work so I can't "try it again"...and don't want to!  =)
Anyway, I've had success with this method.  Good luck!
Posted on Aug 30, 2008
informatica
  • 1114 Answers
SOURCE: HP Photosmart C6280 Scanner
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart C6280
See page 80:
You will need the "All in One" software for your computer:
Software
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 23, 2008
  • 86 Answers
SOURCE: HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
Posted on Aug 10, 2009
Riztech
  • 731 Answers
SOURCE: we have an hp wireless photosmart premium printer,
I guess that the printer is missing scan driver, please reinstall the printer software.
Regards
Riztech
Posted on Feb 23, 2010
Testimonial: "I did what you suggested. Our printer is now scanning. Thankyou so much."
How do you scan using the photosmart scanner. I am trying to scan a document to send by email
Please use HP Solution center to scan and send via email. For more information Click here.
Regards
Riztech
Jun 16, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
Ok i bought an HP Photosmart B209 but how can i scan a picture into my computer?
You can use the program that comes with the printer. Its called HP Solution Center. There you can view your printers status, etc.. In addition you can choose to copy, scan or print files.
May 16, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
How do I set photosmart B209 to enlarge copies?
http://h10032.www1.hp.com/ctg/Manual/c01796502.pdf
Pg 57 Item c, where is says touch size, instead of fit to page, you should have other options to increase or decrease the size.
Another option it to scan the item to the computer then print and enlarge during the print process
Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
I just brought a new HP Photosmart B209 and as long as it is hooked up to the usb port it is fine but as soon as i disconnect it from the usb it says it is offline. how can i get it to stay connected to...
I suggest that you turn off the printer power, then unhook from usb. That disconnect from usb can sometimes scramble the printer driver and control firmware, and require a reinstallation. Also, plug the printer directly into a wall socket, especially for scanning.
Nov 28, 2009 | HP PHOTOSMART PLUS B209A All-In-One...
HP Photosmart C3135 is slow scanning documents
You can speed up process by choosing a low quality of scanning. Decrease the DPI ( Dot Per Inch -parameter) to 100 dpi or 200 dpi
Mar 07, 2009 | HP Photosmart C3135 All-In-One InkJet...
HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Mar 04, 2009 | HP Photosmart 3210 Printer
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
313 people viewed this question
Clive
Clive
