Question about Sony KDS-R50XBR1 50" HDTV
Yellow line on right side of screen
I have had my tv for about 2 years. I noticed that if watched a channel that was not being broadcast in HD a yellow line would appear on the right side of the screen. This line is about an inch think and runs the entire length of the screen. This line would eventually go away. Now, I when I watch a channel in HD the yellow line is present on the right side, as well as the top right corner, and it does not go away. Any ideas??? Thanks, Tony
  • slyaggie May 06, 2008
    I have a similiar issue. The lower right corner of the screen is yellow and stays that way for all channels and dvd's. It is right at 2 years old. The lamp went out and has been replaced. The problem was not corrected when the bulb was replaced.
  • xm man Jul 10, 2008
    I have the same problem. TV is just over 2 years old and out of warranty.
    Please help.
    Thanks
    Tony C
I had the same problem. Your optical block needs to be replaced. Good news from Solution #1 above is that you get a free optical block!
Posted on Jul 19, 2008
Go to this website and read what it has to say, your TV's have major problems.
http://esupport.sony.com/sxrdsettlement
Posted on May 22, 2008
Brand new TV with Light leakage on the screen
I happen to have the same tv brand, size, and problem. The only difference is model. I bought mine black friday 2012 and its got screen problems. Im looking for a solution also to why it has the problem it has. It was working great for the time being until i noticed cloudy white spots around the perimeter edges. I found out its do to a few possibilities. One is the one thats wrong with mine that i believe is dead pixels. My tv doesn\'t look damaged in the screen butt when the image darkens while watching tv u can see it. Its like a bleeding discoloration. Me personally im taking mine back to either get my money back or new tv. From ur breaf description sounds like u have the same issue except yours came that way.if u look at my follows on here u will see pictures of my tv and the issue to my screen. I bought mine from best buy. So i got a thirty day store return warranty plus i purchased a 2 year warranty. So im going back and going to see what they are going to say. I advise u to probably do the same especially if u got warranty.
As far as changing ur setting for HD picture quality with ur dish is to go through your menu options on the dish.i use comcast so mine is different butt im sure in a way the maybe might b in somewhat similar. With comcast theres a format button on the front of my box that i can press to change different format quality. If that dont give u what your looking for then see if you turn off your box while tv is on and then press menu on box and see if a user menu pops up if so then u should be able to change quality. You then can program it to be 1080 if ur using hdmi or components. One thing with comcast box is that i can make every channel 1080 bt the regular channels that dont broadcast that quality makes the picture smaller. So then u have to have HD channels to get 19080 quality. Butt u can get a good quality setting still with regular broadcast channels by overriding to 480p or to the best quality its puts out to that channel. Most broadcast channels set out a 480i or a a better HD 480p. Other than that you have to have HD channels and then ur box should automatically format to 1080u quality on the HD dish channels so you dont have to keep changing. Then when change ur channel back to standard broadcast channel it will automatically format to back to 480peither and so one as you change channels. Well hope it all helps and you got what you were looking for.
Dec 04, 2012 | Westinghouse " 46"" Class - LED - 1080p -...
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
I am having a problem with my new vizio tv. I am
Try this solution....
1) On the original TV remote press the menu button.
2) Scroll down to SETUP and press MENU button to select it.
3) Scroll down to WIDE
4) Use the LEFT and RIGHT arrow keys to adjust to your viewing preference.
**** NOTE: When you adjust these settings you may notice a difference in the picture on the HD channels. When you are viewing an HD channel but the network is not broadcasting that show in HD they push in the sides to compensate and try to make it a sharper picture but know this is normal.
Good Luck and please rate this solution....
Jan 10, 2010 | Vizio VF550M 55 in. LCD HDTV
I'm new to the HD world...just purchased a LG 42LH40 a couple days ago...and have a couple questions to make sure my TV is operating right. 1) When watching an HD channel (CBS for instance) there is about...
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Jan 09, 2010 | LG 42LH40 LCD TV
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony KDS-R50XBR1 50" HDTV Logo
268 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
