Question about Brother HL 2140 Laser Printer
The paper is stop in the printer
There is a paper stopped in the printer! What should I do?
    Scholar:
  • 119 Answers
Open the printer remove the toner and slowly pull the paper out. Pull in the natural printing direction of the printer, so if the printer pulls the paper from top-tray to bottom-tray when printing you should pull the paper from the bottom tray outwards
Posted on Jul 15, 2010
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Printer stops after the first paper
while all 3 lights lit up hold go button and different light pattern if big and middle light are on fuser if just big light scanner if anything else post light pattern
Jul 27, 2010 | HP LaserJet 1100 Printer
Stop Printing
Hi and thank you for using fixya:
To stop your printer from printing while printing press stop or cancel in your printer control center. Also you can click stop or pause on your computer print dialog box,
1-right click on top of the printer
2- click pause on current job printing
good luck!!
Apr 08, 2010 | HP PSC 1350 All-In-One Thermal Printer
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has...
The problem is that the metal paper stop is not fully recessing into the guide at the rear of the printer and the photo paper is catching on the lip on top of the stop. Take the back cover off the printer and check that the guide has not moved out of position. Also try to twist the photo paper tray to the left or right so the stop lines up better with the guide recess. This worked for my printer tempoarily, but then things went out of allignment again, so I took a slightly more drastic step. With only a single sheet of photo paper in the tray, print another photo. When the photo tray slides back to deliver the paper to the rollers, unplug the power cord from the rear of the printer to stop the tray from moving forward again. With a pair of needlenose pliers, bend the lip on top of the metal paper stop upward. This fixed my problem permanently.
Oct 19, 2009 | HP C7200-69016 Network Adapter
How can i stop the out of paper sensing permanently(Deskjet810C)
all you have to do is make sure there is paper there or put something on the sencer to make it think ther is paper. please rate me
Dec 18, 2008 | HP DeskJet 810c InkJet Printer
Paper stops
Check that the rear paper sensor feeler arm is not broken. It is the little black plastic tab that sticks up in the middle of the paper path when your looking at the back of the printer with the cover open. If you can't see it, it's probably broken.
Aug 06, 2008 | Lexmark E234 Laser Printer
Will not stop printing
As above my printer will not stop printing. As long as it as paper it continues to run paper though.
Sep 11, 2007 | Compaq Inkjet Ij300 Printer
Brother HL 2140 Laser Printer Logo
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
