Question about LG DH504E GoldStar Dehumidifier
It just humms...it no longer pulls moisture out the air nor does the motor come on
  • 57 Answers
Bad compressor
Posted on Jul 16, 2010
How does a dehumidifier work
exactly the same way an airconditioner does but in reverse and does not provide any air heat/cooling
a change in gas pressure(compressor) over an partial obstruction(oraface) changes it''s temperature simple physics results in pulling heat/moisture from surrounding air and condenses it drops water into bucket by force of gravity chilled moisture free air gets sent out of case thru slots
Oct 06, 2014 | Dehumidifiers
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Ice forms on the coils. Would wet clothing hung in the area contribute to this problem? The temperature of the area is in the high 50's - 60's.
Yes. Wet clothing would act to put Humidity in the air. think of the air as a sponge the more you heat the air the more the air will take moisture out of its surrondings. The more you cool the air the less moisture it can hold.
a Dehumidifier is a reverse refrigrator.. Air is forced over cool coils and the moisture forms and freezes on the coils (ice). The unit turns off and the coil and ice takes heat up from the surrounding area (makes room colder;Clothing takes longer to dry; The temperature in that room should be were people reside 70-80 degrees). the ice melts and water drips into a holding container which you dump periodically. Solution: 1. remove wet clothing or 2. raise temperature in room. 3. put a space heater in that room instead of Dehumidifier
Nov 29, 2010 | Dehumidifiers
Our dehumidifier is no longer pulling moisture out of the air. I took the back off and the fan is still running. So motor or condenser? And is it worth fixing? The machine is approximately 6 years old.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 28, 2010 | Kenmore 54501 Dehumidifier
Bucket not filling, unit seems to be making more noise
If you are running and not pulling moisture first check air flow. Vacuum the front and back grills and make sure the coils are clean. If you have good air flow the cause of the problem is most like a sealed system issue. This is most commonly a refrigerant (freon) leak. check your use and care manual to find how long the warranty on the system is, sometimes it is as long as 5 years. If it is out of warranty then the repairs are more costly than a new unit.
Jul 24, 2010 | Whirlpool AD65USL / AD65USM Dehumidifier
(New Unit) Motor Runs, Does Not Extract Moisture
Try setting you temperature or fan speed lower this may help.
In order for the unit to remove moisture the coil has to be below the dewpoint.
Aug 02, 2009 | Haier HD451E Dehumidifier
Dehumidifier does not pull moisture from the air
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 09, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
Comfort-aire Dehumidifier bhd-651
Most likely the fan motor is broke. I have seen several units with bad fan motors.
Jun 26, 2008 | Comfort-Aire HD-651 Dehumidifier
LG DH504E GoldStar Dehumidifier Logo
59 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
