Question about Dishwashers
I have a Bosh DLX Series dishwasher, about 6 yrs old. The filter is clean, there are no cracks on the cleaning arm, the hook ups are all good to the sink, the temperature of the water is hot (fine) BUT we are not getting a clean rinse out of it. there is residue that's left on the glasses making them look cloudy. We have rinse agent in the dispenser. Please help. Thanks, Deana
  • 6,784 Answers
HI. This is essentially caused by a slow build up of calcium deposits that can accumulate overtime. The deposits will build up in the recirculation hoses and inside the dishwasher, as well. This build up will induce the cloudy, filmy substance you see after the rinse cycle. I recommend to purge all hoses(drainage and recirculation). Once you have purged the hoses properly, Kindly purchase a dishwasher cleaner(calcium remover).There are a few out there. I would advise to use Dishwasher magic. This is specially formulated to remove such build up and prevent it from returning, quickly. It leaves behind a barrier that will prevent the minerals from sticking. Click Here to purchase this good cleaner online, if you choose.
This will correct the issues you are experiencing.
Posted on Jul 15, 2010
  • 3 more comments
  • Michael Masters
    Michael Masters Jul 15, 2010
    • Additionally; Be sure to check the port holes located on the sprayer arms inside this unit. You can use a large tooth pick or a similar probe to clear out any debris that may exist in the small water ports on these arms. This will increase the velocity of flow.
  • dslater285 Jul 15, 2010
    Can I just run vinegar through the system, i.e. pour one cup of vinegar into the dishwaher
  • Michael Masters
    The vinegar bath will not achieve optimal results. That particular compound is only good for mold removal, and not so good for dissolving calcium. It is also very pungent in order. I only recommend the vinegar solution for mold and bacteria issues.
    hi there,
    Can I do the same thing or at least help things out by running vinegar through the dishwasher?
    Thanks
    Deana
  • Michael Masters
    As I stated in my most recent post, The vinegar treatment will not work as efficiently as the formulated cleaner i have recommended, however, you can use the vinegar bath, if you wish. It will temporarily remove some of the build up, but not all. The calcium will return. Plain vinegar will not leave behind the protective barrier. The barrier left behind by the cleaner I recommended will prevent the minerals from sticking to the hoses and inside of the unit, more efficiently.
Bosch shu6802 use and care manual
Oops! whats your question? If you need a manual, you can go on the Bosh web site to request one.
If your electronic board is giving problem....and the machine is more than 6 yrs old, and the user manual does not help..be prepared to buy new. The Bosh are good except when to board goes...
Oct 17, 2013 | Bosch Dishwashers
Our GE Profile is'nt cleaning like it used to. 5 yrs old. We have well wanter. Could a filter etc. be plugged?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 01, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
THe dishwasher is not cleaning properly. Dishwasher is about 5 yrs old. Have put rinsaid through and run a dishwasher cleaner through too and still not cleaning thoroughly. Any ideas?
that is a common issue,, make sure the screens below the spray arm is clean,, then take the spray arm off and clean it out good, top one also,, run the dishwasher (empty) with white vinegar and bleach, after run it through a rinse cycle to clean it out again,, it starts doing that after the build up of food and detergent,, sometimes it is necessary to have someone take it out and clean all of the hoses and pumps
Feb 10, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
GE spacesaver won't clean dishes, ran finish and dishwasher magic, still won't clean. Ideas? Only 3-4 yrs old.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 05, 2010 | GE Dishwashers
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Bottom of my Bosch dishwasher not cleaning dishes, top tray OK have cleaned / taken apart
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Feb 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Dirty dishes
You need to take the spray arm off of the bottom and get down to the filter: there's probably food trapped in the filter somewhere, not able to drain out and it keeps recycling onto the dishes at each cycle. Good luck!
Jul 17, 2008 | Sears 24 in. 14181 Built-in Dishwasher
Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
May 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
