Question about Amana Refrigerators
Freezers compresser will not kick on it trys reason:power outage tried un plugging all night still not working
    President:
  • 1,218 Answers
Good day,
Good chance the compressor was damaged. First however, you can check the compressor starting components.
These components are clipped to the side of the compressor and are held on with a retainer clip.
First, unplug the machine, remove the retainer clip and pull the components off of the compressor.
The components are made up of the thermal overload protector, start relay and on most models a start run capacitor.
Take them to an appliance parts house. Most are more then willing to test them for you.
Take the complete model number with you.
If any test bad, replace. If they test O.K. then you will need the services of a qualified service tech to test the compressor.
If the parts test O.K. and the machine is under 5 years old, then call your dealer for a warranty service call, since the outage may or may not have been the cause of the problem. If it is a bad compressor, and no sign of storm damage is apparent, the warranty dealer would replace the compressor free of charge.
Posted on Jul 15, 2010
Hello I have an HMCF7W1 Magic Chef freezer, after a power outage the power light comes on, but the Run light will not turn on and everything is thawed. What can I do?
Perhaps the power outage, was caused by your freezer?
When you think a reset would help, the run light should come on, after a little while. But perhaps only the thermostat is defect.
Be aware there can be so many causes, and none has to be related to the power outage, for your freezer not to work.
It would be virtually impossible to see what is wrong, from a distance. Better try to bring the food to a working fridge and call a tech to solve the problem.
Feb 08, 2015 | Magic Chef Freezers
After power outage for about 2 hours, my freezer wasn't freezing. high temp light and alarm came on. the compressor was humming but not kicking on. i unplugged it and i heard ice falling during the night....
call a repair service or go buy a new one . could be the starter on the motor but sadly we can not test it since we have no access to it
Feb 13, 2018 | Freezers
Reverse Polarity Code
check the green ground wire, make sure it is connected
Mar 12, 2013 | Heating & Cooling
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
Grrr noise that stops when doors are opened
The noise you are hearing is probably the fan blades hitting some ice build up. Un plug your refrigerator for over night and it will defrost melting the ice. If it still makes the noise after that then the fan motor is going bad, you will need to replace it soon. The reason that it stops when you open the door is because the power is cut off to the fan when you open the door.
Nov 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
Jul 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
RCA HD52W59
check the fuse its located on the small rectangle board which is on the right side looking in the back its the board closet to where the screen is.
May 12, 2008 | RCA HD52W59 HDTV Projection Television
Refrigerators Logo
188 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
