Question about HP LaserJet 1320 Printer
I install proper driver for hp 1320 printer.when I print any document from pc it not give me any print..but when I switch off & on to printer it give me print..can U plz Help me to solve this problem.
  • 10,421 Answers
I am using HP Laser Jet 1320 Printer i have a problem while printing as follows PCL XL error Sub System: Kernel Errror: Illegal Tag Operator: 0x1b Position: 6
This appears to be an issue with the driver.
Before replacing the driver though, make sure it isn't just the document itself that is the issue.
Try printing several different documents. If all other documents print, there's a problem with the document itself.
If several, or all documents from multiple sources (not all generated from the same program) then it's time to completely uninstall the driver, and then go to www.hp.com and get the driver specifically for your operating system for that printer and install it.
Remember to reboot between the uninstall and the reinstall.
If this yields the same results, then install an HP laserjet 4 driver on the same port as the currently installed driver using the add printer function in control panel/printers.
print the offending documents through this driver by selecting the HP Laserjet 4 as the printer when printing. If this solves the issue, make the laserjet4 the default driver.
Jun 04, 2011 | HP LaserJet 1320n Printer
My HP LaserJet 1320 will only print a single copy of a document despite filling in the 'number of copies required'.
make sure the toner is proper and it is not empty just re-install the printer driver aslo.
Jan 12, 2010 | HP LaserJet 1320 Printer
I recently installed PDF Adobe Professional 2009 and now cannot print on *.pdf files on my HP 1320 printer. I have increased the Memory on the printer to 512Mb and still cannot print. Any ideas?
Do all your other documents print correctly? You should first try to update the drivers for your printer. You can also try to print to file within the Adobe software.
Nov 03, 2009 | HP LaserJet 1320 Printer
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Lost my cd to install my 1320 to a new laptop
OK, for starters click on the link below and then select your printer, as the 1320 can be 1 of several according to Hewlett Packard. Check the underneath or it may be printed on the top.
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&tool=&query=1320
When you have identified the correct printer select it from the list. Another page will open select 'drivers and software'
Select your operating system and then select the driver to download. Save it to your hard disk drive(remember where you save it to). Run the file you have just downloaded and then follow the instructions that the software gives.
Even better if you give me the exact model number for your printer I can give you an exact link to the driver that you need.
Jun 25, 2009 | HP LaserJet 1320 Printer
HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Aug 05, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 problem
For this you first uninstall any previous Driver. Install the Drivers after restarting your system. After Installing the drivers connect the Printer. Note down now the Driver must be automatically work because HP1320 is a plug n play Printer. If not change the cable used to connect the PC with Printer and if the Printer is auto detected, you will be able to print the Test Page or any other page.
Feb 12, 2008 | HP LaserJet 1320 Printer
Problem HP 1320 not responding
Try changing to a new USB cable
Jan 31, 2008 | HP LaserJet 1320 Printer
HP 1320 PCL
check the printer driver properties settings. look under printing preferences and check the settings there.
May 07, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
