Question about Microwave Ovens
Whirlpool refridgerator ET22DKXBW00 Ice Maker stopped working. What can I try and check out myself before calling a repair person
    Genius:
  • 1,478 Answers
This a common problem with the device, many people are out there searching for solution as regards this problem but are yet to get it.
Take care.
Posted on Jul 23, 2010
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
Ice maker not working and freezer not cold enough, food is not frozen solid, but ice we put in tray does not melt completelyu
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 05, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
No water getting to the ice maker
Either your water line has frozen which happens in side by side refridgerators or your water control valve has gone bad. Include more info for a better solution. I need as much as you can give me.
Dec 26, 2010 | Microwave Ovens
Philips 83-363c Refridgerator
Refrigerator
heatman101
Dec 24, 2010 | Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Thanks for choosing FixYa,
Kelly
Oct 26, 2010 | Microwave Ovens
The ice maker has stopped working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 14, 2010 | Microwave Ovens
N refridgerator not cooling, compressor is warm
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 12, 2010 | Microwave Ovens
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Magic chef microwave quit working
u can cheak master fuse in it take cover off unplug it
Feb 03, 2008 | Microwave Ovens
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
