Question about Grilling
Chaoneng igniter dhl-128 -q need wiring diagram to bbq grillware. want spark.
  • J Slaughter Mar 06, 2013
    I'm having same problem. I purchase for my vermont casting but I think I need to ground a wire.
jyackle5
  • 8197 Answers
SOURCE: I have a BBQ Grillware GGPL-2100 that I had to
You can get a pic on the link below.
http://www.appliancefactoryparts.com/images/breakdowns/2/10275-1.png
http://bbq.about.com/od/gasgrillreviews/gr/aapr042709a.htm
If you need parts you can get on link below.
http://www.appliancefactoryparts.com/gasgrillparts/brands/bbq-grillware/ggpl-2100.html
Posted on Apr 15, 2010
  • 4 Answers
SOURCE: ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Posted on Nov 23, 2008
DAD5bbbbg
  • 111 Answers
SOURCE: Need wiring diagram '70 Chevy 2T trck w/electronic ignition conv
Make sure you give it a good tune up. Make sure that your rotor is moving when you crank it over. If it is moving then you will need to replace the distributor module.
Posted on Apr 01, 2009
  • 14036 Answers
SOURCE: I have a 1985 ford F150thts getting no spark. I
MAKE SURE IGNITION COIL IS GETTING 12 VOLTS.IF NO REPLACE FUSE.IF YES .YOU HAVE FAULTY DISTRIBUTOR COMPONENTS AND IGNITION MODULE.
Posted on Jun 12, 2009
stevenhurc
  • 450 Answers
SOURCE: need wire diagram for 2002 dawoo 2.2 for spark plug wires
here
Posted on Jun 24, 2009
My gy6 150cc will only spark when you let off the ignition what might be wrong
Hi, Tucker usually it's a faulty ground somewhere in the ignition circuit for this scenario you will need your service manual wiring diagram. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
gy6 150cc wiring diagram Google Search
GY6 150cc Ignition Troubleshooting Guide No Spark BD Technical Center
GY6 Engine Wiring Diagram
http://www.firenzee.com/gy6/150cc%20Gy6%20QMJ157%20Scooter%20Repair%20and%20Service%20Manual.pdf
Jul 04, 2016 | Motorcycles
BBQ grillware
Try Calgary bbq center they are on line part could be called burner carrier !
Feb 20, 2012 | Grilling
Why does the flame on my bbq grillware gas grill so weak
If this is a propane (LP) grill, it could be a sign that your regulator is going bad. Try replacing the regulator.
Jul 17, 2011 | Grilling
This is aCG4TDBN (elite with no back burner) aprox 6 years old. The ignitors are starting to go bad. How do I replace them?
First, you need to determine if it is the spark ignitors going bad or the Ignition Module.
If the spark ignitor tips are covered with grease or residue, this will give them the appearance that they're failing. Cotton balls and alcohol, work well to clean the spark ignitors. Also, check the wiring from the spark ignitors back to the ignition module. There may be some wear or even a burn on the wiring. Change the battery in the ignition module. Be sure the new battery is facing the same direction as the old battery, when you install it. Before installing the new battery, check the battery holder for corrosion on the contacts. If you see any, use a Q-Tip and WD40 to remove it.
As far as replacing the ignitors is concerned, you may only have to replace the spark ignitors and not all the wiring. It depends on how the wire is attached to the spark ignitor. If it can be carefully pulled of the bottom tip of the ignitor and then si back on, all you need is the spark ignitor. If not, you'll need the spark ignitor with the wiring attached. All of the wiring, will then have to be fished back to the ignitor module.
More more info on all the parts you may need contact BBQ's Galore 800-752-3085.
I hope this helped you to troubleshoot and determine if any parts do need replacing.
Jun 30, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
I need a new thermostat for my BBQ, where can i get one
Try Calary bbq center the are on line , they could well help you.
May 20, 2011 | Heavy Duty BBQ Parts Igniter Wire...
Cant get bbq to light
Make sure the battery is in correctly, then check the wires from the ingniter to the electrodes, if they are connected and ok, then check to see if there is a spark from the tip of the electrode to the collector box or burner. If there is no spark, then it could be the igniter, electrode or wire. Hard to tell with out trouble shooting.
Jul 06, 2010 | Grilling
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
Change the igniter on a thermos bbq
You may not have to change the igniter. It works like a spark plug (passing a small spark from an electrode (a small wire sticking from the bottom of the ceramic tube at the lower end of the igniter) to a metal plate positioned close to the tip. If the plate gets covered with soot or grease from cooking it won't work. Try cleaning the plate and bending it closer to the igniter tip. If the igniter is really bad and needs replacement, you can get a new one at most hardware stores. Installation is very easy.
Apr 22, 2010 | Thermos Stainless Steel Gas Grill
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Grilling Logo
4,988 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
